Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Dec 08 9:18 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Why use boolean in this instance? I believe bridging faces and then beveling gives a more predictable result. I never use booleans in Silo, probably out of habit, so I cannot give you the "scientific" explanation of why it happens...
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Well i use Booleans to cut the window because i know what it does :}
I learned the boolean in MAX and it worked in Hex ..so that why i do it this way...
But i thought that make a wall from a cube and then cut out the windows .. was a fast way to do it ...
and i the front face was cut out aswell it is a good way to make wall's is it not ...
Damn im starting to believe i do everything wrong ..with modeling :{
Thnx Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
I can find the solution to this strange thing..
I have a Wall ..i use a Cube to make me a window ..so i cut the Cube out of the wall..
When i work with it this looks OK ..i beveled the sides .. etc etc..
Aslong as im working with it i can see true the hole...
But when i save it as OBJ and reload ..ALL of the extra work is there ..See image B
But i there is no HOLE in the Plane of the wall.. See Image A ..
I think i have to Finalize the work but i can seem to find HOW to do that..
THnx in advance
Chris
Chris
My Free Stuff
