Yes, it works for P6.
http://ockhamsbungalow.com/Python/LightPanel7.zip
You can certainly parent lights to an object for this purpose.
One caveat, which probably doesn't concern you in this case:
You can't save the resulting combination as a prop or figure.
If you want to have lights parented to a prop or figure 'packaged'
together, you have to edit the CR2 or PP2 by hand to get the
lights in there!
My python page
My ShareCG freebies
I have a question on parenting lights: whenever I have tried to parent a light to a figure (in P6), it seems that the light moves. Ie., as soon as I parent the light, it jumps from its desired position, before I move the parent figure. Is this normal? Does the Light Panel get around this problem?
Quote - This looks very useful but I can't get this script to work. "Input file not found".
"Exception in Tkinter call back"
Any suggestions.could it be I don't have something installed?
Thank you
Are you using a Mac ?
If so, then your out of luck, as scripts that use a tkInter based GUI won't work on current versions of Poser (there has been a hint that this will change with P7).
Quote - No. I am not a MAC user. I moved the scripts into the proper script directory and am now getting different errors. ::perplexed shrug::
Thanks for your concern
Which version of Poser are you using ?
Does changing just the colour work ?
The most important thing to report from the error mesages is the line numbers, but you can copy and paste the whole message from the window, just click and drag the mouse to select and then use Ctrl-C to copy the text.
I am trying to move and rotate a group of lights but after trying parenting the lights to an object and to themselves, I can't do it. I'm pretty sure I have seen lights in groups that can move together, but I don't recall how or where or what. Does anyone know how to do this?
edited: Just to clarify, I'm using P6.
