Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Depends on what you are previewing. Vue 6 has some new neat toys. Spectral atmospheres and meta clouds look great, but they require a lot to render. Compare Vue 6 with a normal atmosphere and I think you will find it faster.
LVS - Where Learning is Fun!
Peggy's right here, don't use the new features if you want to compare with V5.
And check this out:
I'm having an aweful time with the interface... can't even nail it down enough to submit the problem to e-on. As a work-around, I get everything as close to where I want it as possible in V5I, then do the final adjustments in V6I. Even then, strange things happen.... something that worked first try, stops working, for example.
Not complaining, tho. Just wish I could figure out how to report such randem stuff. Meselfr, what are you using for a graphics card?
Completely different card than I'm using... NVidea Quadro FX3400 here. Guess we're having different problems. I turned the gizmos off, which helped some for me. Still, lots of strange behavior which all appears to be graphics related. But yes, slow and jerky is part of it.
My biggest wish right now is to be able to pan a view. That's the main reason I'm using V5 to set things up.
Guys, check your advanced camera options ( double click the main camera in the world browser), and check that: camera preview is off, and see if you have enabled any post processing effect. If so, untick the boxes. You should only have one the films settings enabled. Close the window and see if the interface gets back to normal. If so, report the problem to e-on, this is supposed to be fixed.
I see a lot of folks talking about performance increases with Vue 6... but I am not seeing it.. simple stuff that used to preview in seconds is now taking minutes... Already turned Open GL off and background redraw thread... what else can I do to speed this up and make it useful (again..)
thx/mes
