Thu, Feb 27, 5:52 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Subject: Material Room and jpeg files
ecko30 ( ) posted Wed, 17 January 2007 at 12:21 AM · edited Thu, 27 February 2025 at 5:47 AM
i'm fairly new to p5 just starting to learn material room and clothes room
material files mt5 work fine
HOW DO YOU USE JPEG FILES IN MATERIAL ROOM?
EnglishBob ( ) posted Wed, 17 January 2007 at 4:17 AM
Attached Link: http://www.ebonshire.net/tut-geep/index.php
Look up Doctor Geep's tutorials at Ebonshire (see link), download the P5 Material Room one, and you should be good to go. Page 5 shows how to add a 2D image map as a texture, and that's what you need to do with your JPEG image. The procedure is similar for using an image map as a transparency map or bump map. Don't forget to check out the other great tutorials while you're there.
ecko30 ( ) posted Wed, 17 January 2007 at 8:04 AM
thanks a lot
don't know if first thank you went through
i have down loaded some of your free stuff at differnt times
thanks again
ecko30 ( ) posted Wed, 17 January 2007 at 9:14 AM
i downloaded the material room p5 file
it works fine there is a lot of info in it
there are a lot more tut on the site that i'll go and download
thanks again  you were a great help to me
thanks
EnglishBob ( ) posted Wed, 17 January 2007 at 9:47 AM
You're welcome. ;) I started with Poser 3 and 4, where the materials are set with a relatively simple dialogue box having few options. My first sight of the material room in P5 was daunting to say the least - "what is all this stuff?" - and it wasn't immediately apparent how to do something simple like apply a texture map to something. Now I wouldn't look back - the node system is very flexible and powerful.
