Sat, Dec 14, 11:05 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 14 2:19 am)
Subject: P7 Renders blurry
muralist ( ) posted Fri, 19 January 2007 at 4:07 PM · edited Sat, 23 November 2024 at 1:22 AM
I just reinstalled P7 and I cannot seem to get the renderer set up right.  Everything is winding up blurry.
plus3d ( ) posted Fri, 19 January 2007 at 4:12 PM
Hi
Have you tryied to increase the render settings to the highest quality? The default settings of firefly render are not excellent, you must change them to get quality.
:) Irlinda
Plus3D
My freebies at Renderosity - CLICK HERE :)
muralist ( ) posted Fri, 19 January 2007 at 4:14 PM
At middle settings now.
plus3d ( ) posted Fri, 19 January 2007 at 4:22 PM
Here it is an example This is a render with country light with the default setting of Firefly
Plus3D
plus3d ( ) posted Fri, 19 January 2007 at 4:23 PM
And now, this is the same render with a higher quality on the firefly renders
Plus3D
plus3d ( ) posted Fri, 19 January 2007 at 4:31 PM · edited Fri, 19 January 2007 at 4:33 PM
This is just one example of firefly render setting that I use
:) Irlinda
Plus3D
Fazzel ( ) posted Fri, 19 January 2007 at 5:58 PM
Quote - This is just one example of firefly render setting that I use
:) Irlinda
Where is the Texture Filtering check box and the Max Texture Size slider?
pjz99 ( ) posted Sat, 20 January 2007 at 2:16 AM
Is it the render that is blurry, or the .jpg file you're saving?  Because P7 has some issues with jpg format compressing too much/losing too much quality.
My Freebies
Anniebel ( ) posted Sat, 20 January 2007 at 2:39 AM
Quote - Where is the Texture Filtering check box and the Max Texture Size slider?
Texture Filtering is in the material room on the texture boxes, you have to adjust it manually for each item, there are 3 settings to choose from. I never used TF myself in P6 as my system couldn't cope, be haven't needed to turn it off in P7 yet.
Don't know where Max Texture Size is, haven't found it yet.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
thefixer ( ) posted Sat, 20 January 2007 at 3:07 AM
My understanding is that P7 always renders at the max. texture size!!
Injustice will be avenged.
Cofiwch Dryweryn.
Dizzi ( ) posted Sat, 20 January 2007 at 3:30 AM
Poser 7's firefly doesn't need to load all textures in memory before it can render (it'll load/unload them). Thus there's no need to reduce memory usage via max. texture size - as that's been a bad work around anyway.
