If anyone knows what's wrong here, please let me know!
Smoothing is not the problem. This happens with smoothing on or off, both global and per object.
It renders fine in the Poser 4 render engine, by the way.
It may be that S.T.O.M.P. mauled the .OBJ file. I'm going to try from the pre-STOMPed base objects
The bad quality of the UVmapper image is due to the screwing up of UV coordinates by 3DS Max.
The quads of the .OBJ are cleanly welded.
Normals forward does not help, I checked.
is this a small piece? like a broach or button or something?
if you turn off the shadows does it look ok?
if so. put something else in the scene. a person or prop anything.
My Homepage - Free stuff and Galleries
Without shadows it looks OK.
I'm going to check for double sided polys
The object is not very small in Poser terms - it is one of the cups of an armored bra.
I checked something else too. The cup was exported as a poly from Max. I converted it to a mesh before exporting, and that seems to help.
The editable poly was the problem. The new export renders as it should.
The image above shows the UVMapper results (none too good, I know) and the Poser preview results of an object I have modeled as part of an outfit.
The result in the Poser preview window is what I expect. The skull image is a simple black/white image map.
My gallery My freestuff
