Thu, Feb 27, 12:56 AM CST
Vue F.A.Q (Last Updated: 2025 Feb 23 3:59 pm)
Subject: Can I render a wireframe in Vue?
LMcLean ( ) posted Mon, 30 April 2007 at 12:29 PM · edited Wed, 26 February 2025 at 11:33 PM
Just wonderin if it's possible to render the wireframe of my model in Vue. Thanks
wabe ( ) posted Mon, 30 April 2007 at 1:03 PM
Unfortunatley the answer is no. Not possible.
What you can try out is to use some grid as transparency map to get the impression of a wireframe. Or even a screenshot from UV Mapper for example as well as trans map of your object you want to render.
pmermino ( ) posted Mon, 30 April 2007 at 2:25 PM · edited Mon, 30 April 2007 at 2:26 PM
May be for Win users:   open your scene with Vue in wireframe display mode  (not OpenGL) toggle in single view, (not 3  sides views) and use a CTRL+PRTSCR or ALT+PRTSCR. Then paste the result in your favorite 2D soft ....
LMcLean ( ) posted Mon, 30 April 2007 at 10:20 PM
Wabe, Thanks. I didn't think so, but I guess I can take a screenshot using "Grab". pmerino, thanks. That's a good tip for windows users.
wabe ( ) posted Tue, 01 May 2007 at 2:52 AM
I did a quick and very dirty test - in my eyes it is possible.
I took an object into UVMapper, made a screenshot of the image there and used this screenshot for transparency in Vue.
I should of course make the contrast stronger for the trans map in Photoshop and maybe the lines thicker. But that is tweaking, the principle works (in my eyes).
The screenshot thing you of course can do on Mac too - cmd-shift-3 is the command for screenshot. Or cmd-shift-4 when you want to define the area you want to get.
haegerst ( ) posted Tue, 01 May 2007 at 11:11 AM
As this is already the second one i hear asking about wireframe rendering i made a basic shot of vue wirreframe rendering.
A pyramid, sphere and cube. In the background you can see a wine glas made from boolean differences.
wireframe
I dont think this is of any use. Maybe ask e-on tech support for a wireframe option that renders the scene without lighting/Athmospheres/textures and with a grid over every object? I guess this is what you are looking for?
Vue content creator
www.renderarmy.com
Javil ( ) posted Wed, 02 May 2007 at 3:27 AM
I tought that in Vue 6 Xstream there is an option above preview.. that only render what you see
in the program itself.. i had made a sample movie of it sometimes..
is that what you mean heagerst?
LMcLean, maybe this is what you want, if you set your settings to wireframe mode and then make a 'standard' render (above the preview)
Javil
more VUE Infinite on -> javildesign.com
LMcLean ( ) posted Wed, 02 May 2007 at 11:30 PM
Thanks I will give it a try!
