Fri, Nov 29, 6:55 AM CST
Subject: Rotating a cube in a loop (Z axis)
oliveramberg ( ) posted Wed, 16 May 2007 at 4:05 AM · edited Fri, 29 November 2024 at 4:41 AM
Hello
I need a rotating cube in a loop. The cube has to rortate around his center (no floating or moving). Whe I am using the animation wizzard (Vue 6 Infinite) and spin the cube around the Z-axis the spin is fine but the cube is always moving. What's the easiest way to solve this "problem"?
bruno021 ( ) posted Wed, 16 May 2007 at 4:37 AM
Why don't you just rotate the cube in side or front view at a non zero time on z axis by using the gizmos? I would move it twice: once at the middle of the animation length, and once at the end. Without the wizard.
oliveramberg ( ) posted Wed, 16 May 2007 at 4:39 AM
Thanks for your advice. What's a gizmo?
bruno021 ( ) posted Wed, 16 May 2007 at 5:08 AM
Do you use Vue6? In Vue 6 you have new manipulators called gizmos to rotate, resize and move objects in the viewports, and the option to do these operations globally ( world space) or locally ( object space).
If you use Vue5, you can use the numerics tab to rotate your cube accurately.
