Thu, Feb 27, 7:13 AM CST
Forum Moderators: Wolfenshire
Photoshop F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
Are you up to the challenge??
Subject: Newbie Help on Transparancy
Terry Mitchell ( ) posted Sun, 10 June 2007 at 4:53 PM · edited Thu, 27 February 2025 at 6:37 AM
I've had Photoshop 7 since it first came out, but have only dabbled lightly in it a couple of times.
I am trying to make a background picture to use in Poser (I have have both 5 and 7) of a subsurface view of an ant colony with an abouve ground view too.  I created the scene using two layers with heavy noise filter for the subsurface ground texture and ligt noise for the background of the tunnles, then erased the aboveground view on the layer with the light noise.  I'm left with a .psd file as a background in Poser in which I need to make the above ground portion transparent in Photoshop so I can add aboveground elements elements (plants, peiple, etc.) in Poser and not have them show against the white aboveground background.  I can use the magnetic lasso tool to select the white aboveground view portion in Photoshop, but I'm stuck knowing what to do next to make this portion transparent in the final .psd file for imprtinging into Poser.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
spedler ( ) posted Sun, 10 June 2007 at 5:53 PM
If I understand you right, then you can just flatten the image, select the part you don't want by whatever means, then delete the selection. The deleted section will be transparent and you can save it as a .psd or .png.
I think another problem may be that Poser doesn't appear to honour transparency either in the background image or when applied to an object. A workaround might be to create a transmap and instead of putting your background image into Poser's background, create an appopriately sized and positioned plane and apply the image to that, so the plane acts as a background. Then you can apply your transmap to the plane and mask off the part you don't want to to see.
Steve
tantarus ( ) posted Mon, 11 June 2007 at 1:55 AM
When creating new document in PS, check "Transparent" box on very bottom. It will create transparent document. Or DONT work on background layer and delete it before saving. Dont flatten the layers but merge them to preserve transparency.
You can save transparent image as .TIFF or .PNG (.GIF is for web).
Tihomir
Open your mind and share the knowledge!
