Fri, Nov 29, 2:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: Python Script to Stop "Foot Skating"?
Terry Mitchell ( ) posted Sun, 24 June 2007 at 2:33 PM · edited Mon, 25 November 2024 at 1:48 PM
I vaguely recall past mention of a Python Script that would stop a figure's feet from "sliding/skating" along the ground instead of staying planted firmly in place during each step when in walking motion.  Is there such a thing (or another tip) to solve the problem?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Miss Nancy ( ) posted Sun, 24 June 2007 at 2:41 PM
that was ockham's "no skating" script IIRC.
Terry Mitchell ( ) posted Sun, 24 June 2007 at 2:44 PM
Thank you.
Do you recall if it was a freebie or a purchase item, and whether it was availabel here at "Rosity?
lululee ( ) posted Sun, 24 June 2007 at 4:45 PM
B
Terry Mitchell ( ) posted Sun, 24 June 2007 at 4:54 PM
Assuming that "B" means it was a freebie, I couldn't find it using the search function for either "Ockham" or the python script itself.  Maybe I missed something?
Valerian70 ( ) posted Sun, 24 June 2007 at 4:56 PM
I'm guessing B is for Bookmark and that if the script was a freebie then it may well be in the forums, try searching these (best of luck to you - the search function is not great!)
Miss Nancy ( ) posted Sun, 24 June 2007 at 5:28 PM
Terry Mitchell ( ) posted Sun, 24 June 2007 at 5:40 PM
I think that's the script I was looking for.  I'll give it a go.  Thank you.
Miss Nancy ( ) posted Sun, 24 June 2007 at 6:41 PM
steve sez it doesn't work in OS X iirc. that was true for P6, but it may actually work in P7, as his other scripts do.
Acadia ( ) posted Sun, 24 June 2007 at 8:02 PM
I manually fix that  before I do a cloth simulation. I find that if I don't sometimes I have problems with long skirts.
