Sat, Nov 30, 11:05 AM CST
Subject: Backround movie for rotoscoping?
danb ( ) posted Sun, 24 June 2007 at 6:53 PM · edited Sat, 30 November 2024 at 10:59 AM
I need to be able to sync my poser character animations to a .mpeg i have.  Is this possible to use a movie as a background image in the front viewport?  If so how do i do that?
Miss Nancy ( ) posted Sun, 24 June 2007 at 7:37 PM · edited Sun, 24 June 2007 at 7:37 PM
Attached Link: http://www.philc.net/
apply the movie to the diffuse channel of the poser 1-sided square. see also phil's rotoscoping item.
danb ( ) posted Sun, 24 June 2007 at 9:54 PM
Thank you, very helpful.
danb ( ) posted Mon, 25 June 2007 at 10:54 AM
Which movie format should i be using?  I tried .mov with animation and sorenson codecs but got the message "Cannot load not enough memory".  The file is only 4mb.
Any ideas?
Miss Nancy ( ) posted Mon, 25 June 2007 at 1:38 PM
how many frames? what frame size? altho I admit, it should be able to load a short clip, so that may be the spurious memory error that poser sometimes gives.
danb ( ) posted Mon, 25 June 2007 at 1:59 PM
There are 600 frames at 320 x 240 .  What would be considered a short clip?
Miss Nancy ( ) posted Mon, 25 June 2007 at 2:59 PM
I'm getting 176 MB for that. it may be too much; try shorter clips. IMVHO a short clip is 120 frames (preferably 30 - 60), which is about the standard length between cuts nowadays, given the attention span of the current demographic.
adh3d ( ) posted Mon, 25 June 2007 at 3:39 PM
YOu can try this program, it is free and can be used to capture from videos to 3d or 3d data. like a mocap.
http://www.geeware.com/introduction.html
I have not tried it, but....
adh3d website
