Fri, Nov 29, 6:57 AM CST
Subject: Is such a crisp look possible with Vue 6 Infinite??
oliveramberg ( ) posted Sun, 22 July 2007 at 5:01 AM · edited Fri, 29 November 2024 at 6:51 AM
Hello I am working on a project with interior images. I am trying to achieve a real crisp and clear look like this:
forums.cgsociety.org/showthread.php
My results are OK but not overwhelming.
Any advices, tricks and tips?
Cheers Oliver
bruno021 ( ) posted Sun, 22 July 2007 at 5:19 AM
There are lots of reflective surfaces in these renders, and radiosity no doubt. I don't see why Vue wouldn't do it. It's just a question of where to place the main area lights ( in the windows), and fill lights. One thing though you won't be able to recreate in Vue is the special highligts on the back wall. This is a function within Cinema4D that is't implemented in Vue ( yet?), called environment. What it does is use an image map ( preferably HDR) and use the image in the highlights of the surface, thus recreating the illusion of a window behind the camera. Your only solutiobn in Vue would be to create a highlight function in Vue, and paint a window map in a paint program, load it in the variable highlights function. A lot more fiddling.
Also, Vue uses atmospheres for diffuse/ambient light balance. I suggest you start with a back atmosphere with no sun, no fog and no haze, and build your duffuse/ambient balance using main and fill lights.
Would be nice als to see one of your wips.
oliveramberg ( ) posted Sun, 22 July 2007 at 5:24 AM
Thank you Bruno for your input. Silly swiss man has to ask you, what is a wips? ;-)
bruno021 ( ) posted Sun, 22 July 2007 at 5:54 AM
Work In Progress. Renders you show others to get advice or opinion. And it's not a silly question, or I was silly once too when I asked the same question!
ShawnDriscoll ( ) posted Sun, 22 July 2007 at 6:03 AM
One trick is to render a scene as a huge image and then shrink it down to crisp it up.  If you render normal size like I do, just sharpen the image later using a photo editor.  Not by too much though.
chippwalters ( ) posted Sun, 22 July 2007 at 1:10 PM
Oliver,
Is the above image yours? I see the link to the CGSociety image and understand what you mean about 'crispness.'
If the above image is yours, and you're looking for a way to make it crisper, then there are certainly ways of taking the grain out of an image...if that's what you mean?
-Chipp
oliveramberg ( ) posted Mon, 23 July 2007 at 12:32 AM
Yes, I rendered the image. And I like to have this rather cold and clean look of the image that I have linked to.
ShawnDriscoll ( ) posted Mon, 23 July 2007 at 1:19 AM · edited Mon, 23 July 2007 at 1:20 AM
Remove the bump from your floor.  Add lighting coming from above/behind you aimed at the scene.  Brighten the shadows a bit.  Move the camera up a bit so that more edges/surfaces of the furniture can be seen.
You may have to brighten the lighting outside as well.  Add more reflection to the floor to bounce light under the walkways.
bruno021 ( ) posted Mon, 23 July 2007 at 2:22 AM
Oh, right, I hadn't understood this was your work. Removing the bump from the floor is a very good idea. Also, there is a strange green-bluish ambient lighting in this scene that doesn't look right. Change the ambient colour in the atmosphere editor to a whiter colour. I think also the shadows under the mezzanine material are too dark, same for the upper level ceiling. You may want to brighten this with fill lights that cast no shadows and no speculars. More radisoity samples are needed too, use a custom photon map, and add more photons ( maybe 300000), up the tracing level, and the photon gathering levels too.
oliveramberg ( ) posted Tue, 24 July 2007 at 9:37 AM
Another WIP image. What really bothers me is the fact that I can't see the sky outside because I set up a volumetric spotlight in front of the window. Even though I set all colours of the lights to white there is a strange blue tint on the floor. Not happy yet :sad:
More to come....
bruno021 ( ) posted Tue, 24 July 2007 at 5:16 PM
I think the strange blue tint is the colour Vue tints the sahdows with, and it must be related to the overall sky colour, this one must be a light blue. Change it to someting whiter.
ShawnDriscoll ( ) posted Tue, 24 July 2007 at 6:43 PM
Remove atmo and any haze/cloud layers.
agiel ( ) posted Tue, 24 July 2007 at 8:38 PM
Don't forget the blue color from the transparency of the glass material if you used it for the window. Set it to black to remove the effect, or replace the glass material by a plain transparent one.
oliveramberg ( ) posted Wed, 25 July 2007 at 12:08 AM
Thank you guys for your advices. I'll give it another try and post the result during the day.
oliveramberg ( ) posted Wed, 25 July 2007 at 3:32 AM
Here's another attempt. Took away the fog and haze and used GR. Still not happy....arghhhh.....
ShawnDriscoll ( ) posted Wed, 25 July 2007 at 3:38 AM
Increase photon count?
oliveramberg ( ) posted Wed, 25 July 2007 at 3:41 AM
I used the Broadcast settings for the render. I assume I can find it somewhere when I use "User Seetings", right?
bruno021 ( ) posted Wed, 25 July 2007 at 5:01 AM
User settings, advanced effects quality tab, click edit, and increase the number of photons .
oliveramberg ( ) posted Wed, 25 July 2007 at 5:02 AM
I increased it to 20. Let's see what happens.
bruno021 ( ) posted Wed, 25 July 2007 at 5:31 AM
Oliver, 20? No, the photon map start at 50000, go for 300000 if your machine can handle it,  and double all the other parameters.
oliveramberg ( ) posted Wed, 25 July 2007 at 6:06 AM
Thanks Bruno. I am renderning with these settings now.
bruno021 ( ) posted Wed, 25 July 2007 at 6:29 AM
Maximum gathering radius value looks very strange, have you noticed?
oliveramberg ( ) posted Wed, 25 July 2007 at 6:36 AM
To me every think look a little bit strange on this screen  😕 This value was allready set like that. What would you recommend?
bruno021 ( ) posted Wed, 25 July 2007 at 6:40 AM
Hang on, maybe it's me. It looks like your real world units are set to imperial (english) units, like feet, right? In this case the value is correct, it's in yards, mine are set to metric, so it is expressed in meters.
oliveramberg ( ) posted Wed, 25 July 2007 at 6:54 AM
I see. 9 minutes left until the render is done (over one hour). Looking forward to the result.
oliveramberg ( ) posted Wed, 25 July 2007 at 2:53 PM
And here's the result after almost one hour of "anti aliasing". Hmmmm....
PS: The reflection map sucks big time ;-)
bruno021 ( ) posted Wed, 25 July 2007 at 3:14 PM
The AA seems strange, you can see some aliasing here and there, very noticible in the creases of the furniture, and also on the window plane.
What are your AA settings?
Also, it could be that the objects are quite low poly
CobraEye ( ) posted Wed, 25 July 2007 at 5:37 PM · edited Wed, 25 July 2007 at 5:42 PM
Yes, it is, if the AA settings for min & max are set identical and very high.  Example 128 min -128 max.  And the Advanced EQ slider is set at 100.
chippwalters ( ) posted Wed, 25 July 2007 at 7:01 PM
Oliver,
If you post your scene file, I'll be glad to take a stab at doing an indoor render for you.
-Chipp
oliveramberg ( ) posted Wed, 15 August 2007 at 3:11 AM
OK - here's my next WIP Image. I think It's getting a lot better. Vue generates sometimes weird colours. The plant pot for example is brown but appears bueish...strange.
I will post my settings as well. Any forther tips are very welcome.
oliveramberg ( ) posted Wed, 15 August 2007 at 3:15 AM
And here are the settings:
chippwalters ( ) posted Wed, 15 August 2007 at 4:16 AM
Wow Oliver, that looks really good! Looking at your settings, it must have take quite some time to render! I'd also like to see your atmosphere settings as well, and tell us how you have lit the scene.
best, Chipp
eldritch48 ( ) posted Wed, 15 August 2007 at 8:04 AM
I'd like second both Chipp's congratulations, and his request to see the atmosphere and lighting settings!
Do you find that setting the quality to 62% helps?  Everything I've read says that above 46% the benefit is minimal.
Peggy_Walters ( ) posted Wed, 15 August 2007 at 8:22 AM
With the latest updates, you can set the Advanced qualiity setting to as low as 30% (and yes, anything over 46% is a waste of time).  It will save a ton of time and make little difference in your render.  The biggest improvement to the render is setting the quality threshold slider in the AA setting to 75-80%.  Go to 100% for really fine details.  Don't add more subrays until you max out this slider first.
LVS - Where Learning is Fun!
oliveramberg ( ) posted Wed, 15 August 2007 at 8:44 AM
Thank you guys for your tips. I'll check it out. Here are the athmosphere settings.
oliveramberg ( ) posted Wed, 15 August 2007 at 8:48 AM
and here are the lights
CobraEye ( ) posted Wed, 15 August 2007 at 11:16 AM · edited Wed, 15 August 2007 at 11:24 AM
The Advanced Effect Slider has has made significant improvements to my renders when it is past past 67% Problems with shadows, grain, light, water and clouds are gone when this slider is set to 100% The least benfit I see from your settings is the texture AA which I leave completely off. I would definitely use AES at 100% and up the object AA if you really want grain free renders. I strongly disagree that 46% is all that is needed.
