Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
This does involve many texture maps and that's what predominantly creates that "look". The lighting looks simple enough: one main light with shadows turned on and a fill light from about the 90 degree left position with shadows turned off and intensity set to something lik 30 percent. You'll just have to experiement a bit! :) Mark
As you can see the scenery in this example image is pre-rendered, but it also has the painted look I am after.
So far the only good renders I can get are photorealistic, so I was wondering if any one could give me a few ideas as to what settings or plugins I should use to get this kind of render.
