Fri, Nov 29, 4:22 AM CST
Subject: how do you make the ecos invisible?
estherau ( ) posted Fri, 27 July 2007 at 9:48 PM · edited Fri, 29 November 2024 at 4:04 AM
I am trying to render a poser person and make everything else invisble, but eventhough I've ticked the hide from render box, and also checked "render only visible layers" and also closed the little eye on the layers, the ecos still show up when I render. Love esther
MY ONLINE COMIC IS NOW LIVE
bruno021 ( ) posted Sat, 28 July 2007 at 3:17 AM
If they are painted ecos, and not "parented" to a specific object, I think you can't hide them. But if they are "material eco" then hiding the parent object should hide them also.
Arraxxon ( ) posted Sat, 28 July 2007 at 5:56 AM
Mmh ... why don't you just use two versions of your scene ... one with and the other without eco ... or if you want to render just the Poser person and switch everything to invisible - then just erase the eco objects (the automatic and/or hand-drawn ecos) just for that render - shouldn't harm anything, if you have your comlete scene (with the eco) saved on your harddisk ...
estherau ( ) posted Sat, 28 July 2007 at 6:42 AM
yep thanks. that's what I did. Love esther
psyvampiress ( ) posted Sat, 28 July 2007 at 10:20 AM
The way I do this is change my eco to objects(if painted) and after i render what I need. I revert back to instances :)
sorry forgot to mention I hide the objects from render lol  :D
estherau ( ) posted Sat, 28 July 2007 at 6:21 PM
aha
keenart ( ) posted Sun, 29 July 2007 at 3:05 AM
Why not put the poser figure on one Layer by itself, and hide all of the other Layers.
Then you could render with the setting Only Visable Layers checked?
jankeen.com
estherau ( ) posted Sun, 29 July 2007 at 3:36 AM
maybe because the ecos were global or something, but making the layers visability invisible didn't stop the ecos showing. In the end it was easier to make a copy of the file and delete the painted ecos by selecting them from the menu up at the top of vue. Love esther
dburdick ( ) posted Sun, 29 July 2007 at 10:59 AM
The only way I've ever been able to get this to work (when using global ecos) is using the "Render Selected Objects Only" and then select whatever objects you want rendered in the scene.  Global Eco's can't be selcted as objects, so by default, using this mode will not render them.
