Sat, Nov 23, 12:34 PM CST
Subject: Someone Please Help Me With This
MacD. ( ) posted Thu, 24 May 2001 at 7:14 PM ยท edited Fri, 02 August 2024 at 2:55 AM
Today, I started modifying a full wrestling ring set that I would like to post in the free section. But, I am having some trouble with it. It contains a ring figure, and then about 30 other various props that I would like to be included with the figure. Pretty much, I would like it to be set up so that when someone loads the ring set figure, they also load the ring with all of the props attached. I believe I did so several days ago by mistake... Any help would be greatly appreciated. ~Mac D.
JKeller ( ) posted Thu, 24 May 2001 at 7:24 PM
If you want to have the entire scene load at once, I would suggest you File > Save your scene as a pz3 file.
JKeller ( ) posted Thu, 24 May 2001 at 7:26 PM
Oh, and just incase those props were made by someone else, make sure you have the author's permission before redistribuiting their stuff in Free Stuff.
MacD. ( ) posted Thu, 24 May 2001 at 7:40 PM
I have gained the permission already, thanks for the concern :) . But, if I save it as a .pz3 file, will people be able to load the scene and modify each individual prop? ~Mac D.
JKeller ( ) posted Thu, 24 May 2001 at 8:20 PM
Yep. Try it.
Vethril ( ) posted Fri, 25 May 2001 at 1:55 AM
Yes, you can import a pz3 file into a poser scene, just like an object or a 3ds file. And it will retain it's props individual characteristics. =)
