Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
I'm afraid I don't have those items. So I'll kinda take a stab in the dark here. It looks like the JP centerpoint location for the catsuit Forearm is in a slightly different place than the V2 figure. Since it seems to work fairly well except for the Forearm area. I guess I would try this: 1.)lock the V2 base figure (Figure->Lock Figure) 2.)move the catsuit's Forearm so it covers up the base figure's forearm 3.)delete the V2 base figure 4.)click on the catsuit hip and select Edit->Memorize->Figure 5.)save that catsuit to the library as a new name. Call it v2Catsuit or whatever. Maybe you'll get lucky. And this will fix the problem. ScottA
I thought that I had copied all the dials settings over via a script. The channel and valueOpDeltaAdd settings SHOULD be the same. It looks to be something more related to the conforming. I haven't been able to find anyone who's done a stretch (==xScale) like this and then have conforming clothing match up.
