Fri, Nov 29, 8:04 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: Real Skin Shader for D|S?
PapaBlueMarlin ( ) posted Tue, 04 September 2007 at 7:34 PM · edited Fri, 29 November 2024 at 8:02 AM
Is there a shader system that can provide realistic skin effects for Studio.  I have Posework's set, but am having difficulty getting the skin to look realistic.
JenX ( ) posted Tue, 04 September 2007 at 7:47 PM
Part of the way the RealSkin shaders work is by faking SSS (Sub Surface Scattering), and Poseworks' shaders actually have SSS, so the trick is to master SSS, rather than faking it ;).  Have you tried reading up on Poseworks' forum?
PapaBlueMarlin ( ) posted Tue, 04 September 2007 at 8:04 PM
I've peaked into it, but nothing of what I have seen gives the same effect.  I've tried tweaking the settings on Posework's shaders, but the skin still comes looking burnt or oily.
MirageBay ( ) posted Tue, 04 September 2007 at 9:43 PM · edited Tue, 04 September 2007 at 9:46 PM
This is a great shader set for DS.  You have to register to download it, but it's free.
Company: LakeWorks Studios
Creator: Lakys
Website: https://www.lakeworks.com/forums/
Archive file name: USMP-V0.8.5.2.zip
Requirements:
DAZ|Studio 1.4.16.0 or better.
DAZ|Studio Default Shader Presets
Some 3D compatible figure (such Victoria 3)
JenX ( ) posted Wed, 05 September 2007 at 3:03 AM
Quote - I've peaked into it, but nothing of what I have seen gives the same effect.  I've tried tweaking the settings on Posework's shaders, but the skin still comes looking burnt or oily.
What I'd recommend is, rather than start with one of his premade shader presets, is to delve in and experiment on your own.  I don't have D|S open right now, but even just experiementing with the SSS settings for the skin, trying different strengths, changing the colors, etc, can have a HUGE impact on not only your output but creating more realistic skin.  Give me a couple days to fiddle, and I'll see what I can come up with ;)
Boofy ( ) posted Thu, 06 September 2007 at 12:06 AM
Thanks for the link MirageBay.
MirageBay ( ) posted Thu, 06 September 2007 at 7:07 AM
You're welcome, Boofy:)
I should also have mentioned that although this comes with lots of easy, one click options, you can tweak this to your hearts content until you're satisfied with the results.  It's a great way to experiment in Daz Studio if you're new to shaders.
cuba ( ) posted Sat, 08 September 2007 at 8:42 PM
You could check out Pendragon's shader project.
[Forum topic
](http://forum.daz3d.com/viewtopic.php?t=62945) Download page
It has options such as sub surface scattering, translucency, ambient occlusion etc, and does produce some really nice results.
