Well, regarding the second problem, instead of clicking on the eye, look in the dropdown menu above the material settings for the iris material zone. This will allow you to change the iris colour as you desire. The reaosn it's not working is because V4 has another zone overlaying the iris and pupil areas, and if you try to click on the eye, it will automatically choose this one rather than any of the zones lurking behind.
The first one sounds like there's some discrepancy between the eyes' position in the pose file you're loading and in your personal INJ. Whilst I'm not sure, it's likely that all you can do here is readjust by hand until they're back in the right place, and then resave the pose.
JonTheCelt
Thanks for your help,I cant believe i never saw that drop down menu. I have changed the eye colour. :D
The other problem with the placement of the eye is there is no Trans dials so all you can do is move the eye around the position its in! I might try and INJ the morph after i set the pose.
Ill letya know. thanks again!
I fixed it by reloading V4 and applying the pose an INJ again this time it worked. Must have been a bug or somethin.
The finished piece is now in my Gallery.
Thanks for your help.!
The second problem i have is changing the texture/colour of the eye. When i try and click on the eye in the material room another texture apears (which i guess is reflection) so how do i change the Iris colour to ones i have edited/created.
Thanks for reading
