Forum Moderators: msansing
Fractals F.A.Q (Last Updated: 2025 Feb 18 8:05 am)
correct parameter file
F1E8E39B483889372978261A6D1F1262180B621609621408
6311056213066115085F1A0C5E2011513D23455B35406035
3B653544542F50391F5D1F105D160B5D0D065C0A065B0707
4F06004F06004F0600500400510301510200510100520201
5302005A06045B150C5D2514564E0C4F7705618503739302
7DDD938CE6A39BEFB375CC8B50AA6446A2603C9A5C477143
5155305D2413503F0B435B03445A01465A00534102602805
640D035E06025900015802015805015A05005C05005E0700
6108006009005F08005E07005E07005E07005E07005E0700
540B05570E025A11005C18075E1F0E5E24125E29173E572D
3A7845318B4B3B822C45790D537108626A03694302622206
6013015F14045F16075E14065E12055D1101600C015F0A03
620A00670F0364120561150862180A641C0D632111631E0F
71150A6A1409631308621307611307610F035C0D00550601
5504015403005503005704005D05015E06025B0601560600
5506015A0F006018006128036238063E5A03395906345800
3058002E56002E56002E56002E56002D53002D54032E5502
3C56004F3C096223126022125F2112611E0E5F1D0D5F2112
5E29174869004661004559005F26135D22125C1B09611508
6018006018006018006017085F1D0F5A1D185D28163E5801
425D0064420361320B5E231361190B641206690503710502
801900871A068F1B0C9822169B3E1F74723F8DBF6AC3C88E
DCE278F8F69FE7BA9DE8C3B1E2E3D1E6F1B9BEE4BDADDEA7
A5B48B918D6A7E664A6B4E306625136B440381720D50830C
458C4A3FAA723DB67333AF703898593A7835456F09425900
5F28145F1C0C6115075C10005A11005617065D230D425700
385C00365C003855013F55005E23115E1B0B601802601800
60180064230380560A89711B9C860EA8AF83C0CBA3C4E1DC
E7FBDFFFFBFCF1ECF0F1E6D0A4C097798A5E8461396E3722
6028175E29173C56003355003155002F5500305800315903
3B630237663035894B34975736864960653D602C176D2516
893626A44030A23427A31D1C9E0000861A0D741B0D6D2A19
second one
5E620060592B646434656D3D3A823A2397412D834E37705D
55382A6C3421843119A65021C96F28C95F2CCA5031C35744
BD5D56C03628A13B2482422074451B674916625A155A6813
4E8736509040519A484A81504769634B6560634C57717135
6F5016864C008850158A552B7F7B415796516E9951839D51
CBA44DA86C647A45967938636D282C6A2320681F17730B12
72011D3409002F05052B06132B021E2B00283C001C4D0010
750031740029740927632A294A5C30375C44305A5E29694A
19563E064F120D3A101926111E19151D0D1F1E0030140035
0E01202B1121441E1B36252F1B303F162F3A122F35042033
071D31152624153133153D420F3F4D0B43581A49700E6F63
2C76702B68652A5B5B31524E464A35493D2E613C1F5D0F1F
63002F68113C6F063777003472003F6D00495D0035480B32
61168A65057A69006B75004F810030820011740500802000
6C1A074E000B45000E3D02122B180D1722020F2D0000470E
00967E07918C1E889A10997C01A55E009B41007C23226810
4C4C22993F89A24595AB4BA2BB6CA1CB33B2C0037E900663
C60040AB00229100058E00038B0608901400972B00733700
534C041D7300057904007F18038B2C118053289C7500DDA9
48BED757ACD76796D7CE73D1DF64CEFCAD7AF2895DC9BF5D
BCC461CA7275C28569BB985F9E5B42884139753B315B251D
2134062C3B043742032A4F001D530D23453A1A523C2D5644
1A6C1B12633000565100533D01702F00881D00AC3600BA21
1BB23A27AB3036A5294A93514780803398A6AD696FBD4231
D03612BB002B872616771B27552841352D4B124349202B48
5415568B243F98472FBC4E29CF4310B42700981100892700
602800573400501422510E3D2A03441E02411D032812220A
1F260000300E002B1600260F16180D00070406061800111D
000F23001824000C320010440A243B213242442538531B2E
5517134C0A092A0305140F0510201A0B2F39004254036158
0074631B664A187D38206D3C256452283D492D29424E1515
4502054702004619004D0F025E2900812E00942B2098220A
here is my procedure for using these parameters
copy and save the text in notepad and put the file extemsion as .fla
la copie et épargne le texte dans le bloc-notes et a mis l'extemsion de dossier comme. fla
I open the parameter in Apophysis and then open the spiderform heart script by Mr. Daniel Eaton
http://djeaton3162.deviantart.com/
I run the script and use the mutation window to find a flame of interest.I also use other scripts first and then spiderform
est ici ma procédure pour utiliser ces paramètres
J'ouvre le paramètre dans Apophysis et ouvre alors le manuscrit de coeur de spiderform par M. Daniel Eaton
Je cours le manuscrit et utilise la fenêtre de mutation pour trouver une flamme d'intérêt.j'utilise aussi d'autres manuscrits premiers et alors spiderform
translation by http://www.freetranslation.com/
I am sharing 2 parameters that have no beauty persay by their selfs but with the use of Joolian scripts that can be found at http://apophysis.deviantart.com/journal/2038750/
each time they provide a different attractive flame. if it does not on the first try then run the script again.also try the easysphere script also for stellar results
