Fri, Nov 29, 1:30 AM CST
Subject: I'm losing my hair here
Damsel ( ) posted Mon, 05 November 2007 at 4:38 PM · edited Mon, 25 November 2024 at 11:58 AM
For some reason, my mind is blank. :-) I know I have created props and saved them as "smart props" ie...a hat for Vicky 4. Then saved them to my figures library so that I could use MAT Pose Edit to create texture injection files. Now I can't save the props as figures. No plus sign at the bottom and MAT Pose Edit won't save a proper injection file for a texture from the prop file. HELP! :-) Thanks for any ideas. I see other props done by others that you can't save as figure files either, but somehow they did mat injection files for texturing in the Pose folder.
Kathie Berry
Admin/PlanIT3D
Some painters transform the sun into a yellow spot.
Others transform a yellow spot into the sun.
 --Pablo Picasso-
wus ( ) posted Mon, 05 November 2007 at 5:41 PM
forget about saving props as figures, because you can't and because you don't need to. try the 'Poser 5 MAT Writer' here in the freebies. that's what i used for things like that. there's instructions on how to deal with smart props in the readme.
Damsel ( ) posted Mon, 05 November 2007 at 5:48 PM
Thank you! I'll go and check that out. :-)
Kathie Berry
Admin/PlanIT3D
 --Pablo Picasso-
Damsel ( ) posted Mon, 05 November 2007 at 5:49 PM
Ooops, it's gone. :-(
Kathie Berry
Admin/PlanIT3D
 --Pablo Picasso-
wus ( ) posted Mon, 05 November 2007 at 6:17 PM
ouch, that hurts! look, it's bedtime where i live, so let's hope someone else is around to help you with this. otherwise i'll be back tomorrow and then we'll try to get it done, ok?
wus ( ) posted Mon, 05 November 2007 at 6:20 PM
sorry, i could not resist... 😉 (screenshot from polanski's fearless vampire killers)
MegaJax ( ) posted Mon, 05 November 2007 at 6:25 PM · edited Mon, 05 November 2007 at 6:31 PM
Try contacting Netherworks and asking if they can do anything for you as they made the  'Poser 5 MAT Writer'
Edit: They sell a newer version on their webstie
Damsel ( ) posted Mon, 05 November 2007 at 7:15 PM
LOL wus! :-)
And thanks MegaJax, I will do that. And take a look at the website and the newer version also.
Kathie Berry
Admin/PlanIT3D
 --Pablo Picasso-
SamTherapy ( ) posted Mon, 05 November 2007 at 7:26 PM
If you're using Poser 6 or 7, you can save a Material Collection direct to the Material Room.  It works in the same way as a MAT pose except you access them from the Material Room rather than the Pose Library.
Select your prop, then click the + at the bottom of the Materials library.  Select Material Collection from the dialog box, give it a filename and you're good to go.
BTW, no prop will respond to a MAT pose or Material Collection unless it's parented to something.  Nothing you can really do about that, it's just the way Poser works.
Anniebel ( ) posted Mon, 05 November 2007 at 7:32 PM
If you have Poser 6 or 7, you can do it simply by using the material room & a text editor.
In Poser save the MAT as a material collection in the Material room. Then...
  1. Open the mc6 file in a text editor
  2. Replace the top few lines that look like this...
version
                number 7
mtcollection
with this ...
version
                number 4.01
actor prop name
To get the prop name open the prop file in the same text editor & it will be listed at the top next to the word prop
Eg.
version
                number 4.01
prop hat:1
So you would end up with....
version
                number 4.01
actor hat:1
  1. Save the new file as a pz2 file
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
Damsel ( ) posted Mon, 05 November 2007 at 8:46 PM
Very cool! Thank you both!! :-) You guys are great and I really appreciate it!
Kathie Berry
Admin/PlanIT3D
 --Pablo Picasso-
