Thu, Feb 27, 1:38 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: More Tutorial Problems
cryptojoe ( ) posted Sat, 19 January 2008 at 6:57 PM · edited Thu, 27 February 2025 at 1:36 AM
I'm using Carrara 6 Pro, and the hand book is for Carrara 5.
Okay, we are in the Assembly room, the tutorial is saying:
"...click once between the first key frame and the last key frame on the time line for the fan group; notice it turns yellow. (Nothing turned yellow mind you) In the Properties Tray, Carrara displays the properties for the Tweeners..."
Don't see that ether. What I see is posted above.
Is it me, or do I need to buy the same hallucinogens the author is using?
Yank My Doodle, It's a Dandy!
bwtr ( ) posted Sat, 19 January 2008 at 8:27 PM
Sorry, but you seem to be providing a paragraph which is well into a (missing) conversation!
Need a starting point for me--sorry again.
bwtr
MarkBremmer ( ) posted Sat, 19 January 2008 at 9:22 PM
If the Tweener is actually selected (clicked on) in the Sequencer, the Tweener properties will show up.
stardust ( ) posted Sat, 19 January 2008 at 11:18 PM
Here is what it looks like in the Sequencer ... sorry, no drugs needed :)
UVDan ( ) posted Sun, 20 January 2008 at 5:27 AM
Forum Moderator
I see you are already into customizing your interface.  Sorry I have been absent for your thread.  I have my own problems trying to get Carrara to import groups and materials intact with an obj.
UVDan ( ) posted Sun, 20 January 2008 at 5:40 AM
Forum Moderator
**Ok, I got it page 64.**
cryptojoe ( ) posted Sun, 20 January 2008 at 7:22 PM
I click.
See?
Nothing happens!
UVDan ( ) posted Sun, 20 January 2008 at 7:56 PM · edited Sun, 20 January 2008 at 7:58 PM
Forum Moderator
**You are clicking up on the line that says UNIVERSE.   Click on the one that says fan.  You may need to have the fan selected as well.
cryptojoe ( ) posted Sun, 20 January 2008 at 8:08 PM
Okay I selected the fan, but I didn't show that...
"And a one-a"
Lawrence Welk, bubbles going...
cryptojoe ( ) posted Sun, 20 January 2008 at 8:10 PM · edited Sun, 20 January 2008 at 8:19 PM
'And a Two-wa...."
I click in the time line...
...anticlamatic, eh?
Nothing happens...
If it any consolation, I had the fan oscillating and spinning in a looped animation yesterday. But, I still don't understand the selection for the tweeners, whatever, they're trying to get me to understand.
It must be nice to still have a pliable brain!
MarkBremmer ( ) posted Sun, 20 January 2008 at 9:00 PM · edited Sun, 20 January 2008 at 9:03 PM
Hi CJ, You only have one keyframe at time zero. So, there is no tweener. You need to have a key frame also set further down the timeline. Mark
UVDan ( ) posted Sun, 20 January 2008 at 9:34 PM
Forum Moderator
Aha!  Just like in the instructions.:laugh:
ShawnDriscoll ( ) posted Mon, 21 January 2008 at 12:36 AM
Reset your preferences to get all the colors back to default.  Then you'll see.
cryptojoe ( ) posted Mon, 21 January 2008 at 11:31 AM
@Shonner, default burns my eyes!
I can see those little tabs on both sides are the same color as Marks...
So, even if the defalt color for the skins isn't the same, it should have no effect on ones ability to see that something has been selected.
cryptojoe ( ) posted Mon, 21 January 2008 at 11:35 AM
Now, I can move that line thingamabob, and the little arrow thingamajigs, and a tab appears in the whatchamacallit in the upper right hand side. Point is, I can select these items but nothing to do with those Tweener thingies...
MarkBremmer ( ) posted Mon, 21 January 2008 at 11:45 AM
Hi CJ, When this "clicks" you'll kick yourself - like all things in 3D. ;) It sounds like you are new to animation. Dragging a key frame isn't enough, you'll actually need to create a new one so that you have two on the same line. The space between the two key frames (the little black triangles) is the tweener. How do you make a new key frame? Simply move the time marker further down the timeline and then change the item in the scene and Carrara will create a new key frame automatically. I don't know what the tutorial is asking you to move or change but by completing the request with the timeline indicator further along in time, a key frame will be made and then you'll have a tweener also.
cryptojoe ( ) posted Mon, 21 January 2008 at 2:00 PM
Attached Link: http://www.safehaven-uk.org/cryptojoe/Resource Reclamation.zip
Okay, I must have missed something in the tutorial about moving the object...
Yes, I'm familiar with the terms of Timeline and Keyframe; its the Tweeners I'm new to. Im sure they exist, but they were seemlessly invisible in Rhinoceros 3's Bongo Animation program.
Again, the link to my video is above. It will download a 82 Meg zip file
UVDan ( ) posted Mon, 21 January 2008 at 4:21 PM
Forum Moderator
Check the tutorial Joe.  They say to move the time marker down, then move the fan.
dbigers ( ) posted Mon, 21 January 2008 at 11:02 PM
Tweeners are short for what happens in the space "between" two keyframes. Before computers it was up to the artist to figure out the in-between motion and appearance, position, etc. for all the objects for the frames in between keyframes. This was back in the day when all animating was done by hand, not that long ago actually. As Mark said, you must create another keyframe further down the timeline for Carrara to know that it needs to "tween" any property. Say for instance you move the object on frame 60, Carrara will do the work of calculating all the intermediate frames in between. That way, if you scrub the timeline to frame 35, the objects' position will be calculated and the object will be drawn where it should be for that frame. The tweener is just the end users ability to decide how Carrara will make that transition between keyframes.
