Sat, Nov 30, 2:58 PM CST
Subject: Modelling new figures
DarkHound ( ) posted Wed, 15 September 1999 at 12:01 AM ยท edited Sat, 30 November 2024 at 11:28 AM
Attached Link: http://www.worldofdreams.com/chi
Hi, I'm just wondering how you would go about modelling new figures from Poser. For those familiar with the Wheel of Time series, I want to create a trolloc. A trolloc is basically a hybrid mix between a human and an animal. They are bipedal. For instance, imagine a huge human except with an eagle's head and claws for feet and hands. How would I do this, are there any tutorials on something like this? Thanks a lot!
bushi ( ) posted Wed, 15 September 1999 at 1:31 AM
First, of course you need a program that can create the 3D mesh. The price for these range for many thousands of dollars to free. It just depends on what works for you and how deep a pocket you have. There are a ton of tutorials on the web for creating meshes so it might be worth your while to do some browsing to get an idea of what is available in your price range. OK, so you have a 3D model you now want to convert to Poser. If you're still on P3, go to the Meta site and download the Advanced Techniques .pdf. It is /was the bible for converting models to be pose able. In P4 most of the same info is now in the back section of the documentation. If it's P3 or P4 the process is still basically the same. Take a model and do the following: Slice it into parts and name the parts (models can also be set up as collections of pieces) Set up a hierarchy of parts for the model Feed the sliced model and hierarchy to P3/P4 Set up the joints for the pose able model This is a very broad overview but the essence is there. I have some tutorials on my site covering this area. They where origially for P3 but will work the same for P4. Some new tools where added to P4 that help make this process easier but there are still some bugs that need to be worked out. My site is at www.spiritone.com/~bushi
bloodsong ( ) posted Wed, 15 September 1999 at 12:53 PM
heya; if you want to do some simple 'people with animal heads' type things, you can either... A: turn your human's head invisible and put an animal head on it (with the body turned invisible), then parent the animal to the human. (this method leaves a lot to be desired.) B: do the same thing in poser 4, but export an obj with the human body and the animal head (make sure the head is in place). then, edit the human's cr2 file to point to the new obj (save it as a new cr2). then it will be one integrated model. you wanna mess with animal paws... that's gonna be tricky. definitely need some higher powered 3d modelling tools for that.
DarkHound ( ) posted Wed, 15 September 1999 at 10:42 PM
Thanks a lot to both of you. I'll probably use the second method for now, cause I wanna finish this pic asap. But I'll definitely try the first method with 3DS MAX R3 later. Maybe I'll post up the results later... thanks again!
