I've also try to process in Photoshop another of my "intocartoon" test images (see the image in attachment) using some cartonizing Photoship action... the final result is interesting!
Analog-X: If you are talking about this thread, I site-mailed Duo and asked him if he would do a small piece about his work and he was kind enough to oblige, hence what you see here. ;-)
Nah! We Coords only use telepathy for the really important stuff !
Quote - Looking at the tutorials for this program, I got the following idea. using Photoshop and a couple of default filters, and a bit of tweaking for each filter.
Yes, but as you can see the "quest for cartoonizing" is not only on outlining in black the figure, but is also to obtain "flat" colors... ;)
Hi,
Just saw a render by DUO that uses a neat little proggy called 'INTOCARTOON' available for free evaluation here.
http://www.intocartoon.com/
Not too expensive either @ $29.90
If you want to see the effect, checkout Duo's TOON SHADER TEST in the Bryce Gallery.
http://www.renderosity.com/mod/gallery/index.php?image_id=1608453
I'm hoping Duo will come in here and give us the low-down. ;-)
