Fri, Nov 29, 9:10 AM CST
Subject: Illusion!
jedswindells ( ) posted Wed, 06 February 2008 at 10:39 AM · edited Mon, 25 November 2024 at 9:54 PM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1613023
It just happened!and although I can't explain why,I quite like it!  Cheers! Jed.
bobbystahr ( ) posted Wed, 06 February 2008 at 10:52 AM
Weird 4 sure...can this be reproduced with another similar image...ie: a new ocean,model,lighting, but same camera setup....what happens ehen you change the FOV on the camera?.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
SndCastie ( ) posted Wed, 06 February 2008 at 11:05 AM
what mat did you use on the terrain and square plane it might be what did it.
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
Ang25 ( ) posted Wed, 06 February 2008 at 4:07 PM
That is insane. Love it!
RodsArt ( ) posted Wed, 06 February 2008 at 4:57 PM
Did you try selecting all and stepping back the cam view? ...or checking the object list?
Was any part of this Bryce file a merge with another?
It's really cool what ever it is.
Might call it a SOW ghost....whhoooooooooooo.
___
Ockham's razor- It's that simple
jedswindells ( ) posted Wed, 06 February 2008 at 6:43 PM · edited Wed, 06 February 2008 at 6:45 PM
Hi,played around with this a while,learning how to control the 'thing'.it works for any scene (well the three I tried!)   Either a square,circle or plane set facing the camera,close to it and between the object.  In Materials  Lab,clear everything from the A B C D chanellsand set all values to 0.Then  set transparency to 100,and refraction to between 15 to 30.  cheers! Jed.
bobbystahr ( ) posted Wed, 06 February 2008 at 9:14 PM · edited Wed, 06 February 2008 at 9:17 PM
**Well I got intrigued so I loaded a gig shot of Roldo and myself onto a 2D plane and set a number of squares with settings similar to the ones above except I had my Refraction much higher and I varied it slightly over the three. Also varied the distance tweeb camera na squares. It seems to work a bit like a microscope doesn't it...you can notice where the squares over lap a bit more exaggeration of the magnification as well...cool trick...good for abstracts out of *real stuff* for sure.. ...**
I see a sound
Death_at_Midnight ( ) posted Wed, 06 February 2008 at 11:05 PM
wow! that is some effect. I like the boat and those waves, and it's really weird how the "sphere" came out. Really neat tho. But weird in a good sort of way.
bikermouse ( ) posted Wed, 06 February 2008 at 11:24 PM
Yeah; you guys have re-discovered Vile's Telescope! Lens effects work in Bryce including refraction. Now if you discover how to bounce a laser beam off a mirror . . .
lordgoron ( ) posted Thu, 07 February 2008 at 2:14 AM
Awsome effect :)
Some basic rules of optics definitely work in Bryce, has anybody tried to construct a working refractor yet? ;)
lordgoron ( ) posted Thu, 07 February 2008 at 2:30 AM
Err.. yes it works (kind of)... So working telescopes to magnify objects can be made in Bryce ;)
First is with one lense, the second with a second lens...
TheBryster ( ) posted Thu, 07 February 2008 at 7:21 AM
Forum Moderator
LOL I've got a pic on the back-burner that needs just this thing! Thanks, Guys! You just solved half my problem.
pakled ( ) posted Thu, 07 February 2008 at 10:28 PM
there's a very old Bryce tut (probably Bryce 4) which showed this effect. You could make planetary orbit pictures with it, if'n I remember rightly...;)
silverblade33 ( ) posted Fri, 08 February 2008 at 5:26 AM
Pakled,
I remember that! :)
Alas I deleted all my bryce tuts, as I save tuts all the time...probably on a back up CD someplace.
basically you use a lens in front of the camera, to warp the ground/atmosphere into a gentle arc, giving a space-like effect.
In Vue, you can do a similar trick by altering the Camera's field of View.
I recall having a magnifying glass object in Bryce, that did exactly that: magnify as per real glass :)
And a telescope, isn't one or other a default bryce item?
jedswindells ( ) posted Fri, 08 February 2008 at 8:50 AM
You don't need a lens,just a circle or square like bobbystahr used above...
bobbystahr ( ) posted Fri, 08 February 2008 at 10:23 AM
Attached Link: THE TUNES
**Further to my lil test pic, if anyone is interested in hearing what we sounded like that night here's a link...bear in mind we both had massive colds and as this was a reunion of the 2 surviving members of our original jug band, [we hadn't played these tune in* well nigh onto 30 years]* and only had a few weeks to remember 3 sets...not *too* shabby for that....enjoy. My advice is pick the ones you like and delete the rest after you've dl'd it...there is a *fair bit of crap* IMHO.. ...**
I see a sound
TheBryster ( ) posted Fri, 08 February 2008 at 2:33 PM
Forum Moderator
Way to go, Bobby. Be good to hear how 'old-timers' did it. :lol:
