Forum Moderators: RedPhantom
I read your post about SMMV earlier, but you said it wouldnt really be quit like SMV because the body isnt exactly the same (just similar), and the hands and feet would remain vicky's. Is there any way to keep the exact supermodel body and just transfer the head or head morphs? Like a modification to SMV's head rather than modifying vicky's body to look like smv's?
You should be able to se Vickie II or Vickie I head morphs (only) on SMV, you would have to copy and paste them rrom the CR2, or use Morph manager or CR2 editor to get them into SMV's CR2. Actually, as I think about it, you could probably build a head you like on Vickie II and export the head as a morph object too, and fit that to SMV's head, setting it to 1.00 should convert the entire head (including teeth) to th enew look. I'll try that and see if it works. The Vickie II CR2 isn't redistributable, remember, so I can't put the morphs in a SMV update.
Attached Link: http://digitaldreams.bbay.com
You're right ... it's easy to see the difference for sure. SMV is a great work. We have just decided to standardize on the Vicky 2 geometry for now - and track Daz when they go to Vicky 3 whenever. It is just too important for us to have continuity. Ah well... I'll keep twiddling them dials myself and see if I can get close at least :) Again, GREAT work - it just isn't for us :(
Is this possible? Jim, if youre reading this -- Supermodel Vicky is amazing, I love the work you did with her body. She looks far more realistic and appealing than the standard vicky models. However, her head is a little strange - its great for some characters, but its just isnt very versatile for what I need it to do. Is there any easy way to graft vicky 2.0's head onto smv's body? If this is possible, I would probably stop using vicky 2.0 altogether :) If its not too complicated, can someone describe the steps necessary to either graft the head over, or just copy the vicky 2.0 morphs over (if possible)? Jim, with the prettier vicky face morphs out in 2.0, do you have any plans on releasing a 'vicky 2.0 smv update'? Im sure you would make a lot of people very happy if they could combine the awesome body of SMV with the flexible, cute face of vicky 2.0. Thanks
