Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
What format do you save your renders in? If it's JPG, you're compromising the image quality. More so if you use the default setting for JPG in Poser. Save as a lossless format such as PNG or TIF for the best image quality.
TIF is also a safe loss-less image format if for some reason you don't want to use PNG.
What is Post Filter Size set to? Normally it is set to 1, if it is set higher it will make the render more blurry. It does something similar to gaussian blur, and "post filter size" appears to be much like the radius (in pixels) tha gaussian blur works in.
I am having a strange issue - my renders look a bit blurry - I am using a nvidia Geoforce FX 5200 graphics card and rendering at firefly at the highest level - I can't figure it out - any thoughts?
