Sat, Nov 23, 12:21 PM CST
Subject: Shaders - how to display a stripe of a texture over another texture?
Black_Star ( ) posted Fri, 28 March 2008 at 2:09 AM · edited Sat, 23 November 2024 at 12:01 PM
Hi!
Is there any way of combining two textures by displaying a portion (stripe) of a texture over another?I know there was a way by using a black an white map on wich was the stripe in a node (I don't remember wich) in order to define the size and shape of the texture you want to display over.Something like a mask.
Thank you in advance!
Best regards!
PS : is the blender node a good option, or is there any other way around?
bagginsbill ( ) posted Fri, 28 March 2008 at 9:20 AM
Blender is perfect for this. Plug your two textures into it, and then you need to decide what to use to control the blend.
Basically, you want a shape to appear that consists of black or white. The black region will choose Value_1's texture. The white region will choose Value_2's texture.
The shape can be procedural (using nodes) or it can be drawn (using an Image_Map node to hold the drawing.)
This is an example of what I call a "dual" material - a single shader that really has two shaders within it. Your case is pretty simple - same shader logic, just using one of two different color maps in each region.
More can be done - you can make each region appear to be different in every characteristic - not just color (from your texture blend) but also specularity, reflection, bump amount - everything can be different in the two regions.
Here's a thread where I showed this technique to create a dual material that did metallic car paint and plastic decal in the same shader.
Dual Materials with Stencils
Plutom ( ) posted Fri, 28 March 2008 at 9:35 AM
Thanks Bagginsbill, more for me tool box--Jan
Black_Star ( ) posted Fri, 28 March 2008 at 2:20 PM · edited Fri, 28 March 2008 at 2:28 PM
Very informative! Thank you!
PS : this can be doen in the same way, or should I add something extra?As you can see the red color is "bellow" the actual cover, giving it a glassy look...
