Sun, Dec 1, 2:07 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Asking for help with color.
gunsan ( ) posted Mon, 05 May 2008 at 10:38 AM · edited Sun, 01 December 2024 at 2:04 PM
I have got an order to make a portrait of this dog. I have difficulties with the green colors, being too yellowish  mostly around the dog and on the shadow side of him. Is there a way to make the green more natural, and the dog shadow side less yellow, without changing the red colors of the poinsettias?
I have tried changing by hand, but it does not look natural, at least not on the dog.
Grateful for any tips
Gun
L8RDAZE ( ) posted Mon, 05 May 2008 at 11:21 AM
Are you going to reshoot the dog or just do postwork adjustments on the computer?
If your reshooting, check your whitebalance and  make sure its not set to auto, the lighting and colors may be throwing it off and adding a cast to the image.
For postwork,
If you shoot in RAW...you can tweek the white balance settings and make other color adjustments
Or
you can also  experiment with a selective color adjustment layer (photoshop), as I find it gives more control over specific colors.
Joe
gunsan ( ) posted Mon, 05 May 2008 at 11:39 AM · edited Mon, 05 May 2008 at 11:42 AM
Thanks for answering.
I did not shoot it myself, got it from the owner in jpg, not more than 1200x800 in low resolution.
Since I cannot change the photo, I will ty to do as you say in Photoshop.
Even if I will paint it, I find it best to have the photo as good as possible to start with.
The result will be A4 in 300 dpi before I print it.
girsempa ( ) posted Mon, 05 May 2008 at 1:00 PM · edited Mon, 05 May 2008 at 1:01 PM
Hello Gunsan, I applied the Foliage filter from Nik Color Efex Pro to bring out the green, and then applied the White Neutralizer filter to remove the yellow color cast on the doggie... Is this what you were looking for..?
We do not see things as they are. ǝɹɐ ǝʍ sɐ sƃuıɥʇ ǝǝs ǝʍ
3DGuy ( ) posted Mon, 05 May 2008 at 1:03 PM
That leaf in the last picture stands out like a sore thumb.  I don't really see a problem with the shade of green it has in the first picture.
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
gunsan ( ) posted Mon, 05 May 2008 at 1:34 PM
Thanks girsempa for the tip about Niks filters, I have them.
To 3DGuy, if the green seems to stand out too much I could layer it with the original,and test.
Now I am trying this out.
gunsan ( ) posted Mon, 05 May 2008 at 2:07 PM
Maybe something in the middle, will experiment more, thanks
gradient ( ) posted Mon, 05 May 2008 at 2:30 PM
Very Nicely done!
There is another way to eliminate color casts using threshold values...but I won't go into it because what you have done here has worked well.
My only comment is to clone out...or put another leaf over the edge of the flower pot that sits just to the left of the dog.
In youth, we learn....with age, we understand.
Onslow ( ) posted Mon, 05 May 2008 at 2:51 PM · edited Mon, 05 May 2008 at 3:02 PM
You could balance the dogs colours on an adjustment layer and use the mask so that it only applies to the dog and leaves.
This one done very quickly with an adjustment levels layer.  Take center eye dropper and click on yellow shadow area on dog (by the left leg).   Fill the mask with black and paint in the dog and leaves in white.
It could be done with a lot more subtlety on curves adjustment layer and spending more time on it.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
L8RDAZE ( ) posted Mon, 05 May 2008 at 3:08 PM · edited Mon, 05 May 2008 at 3:08 PM
Just a thought....you may want to clone out the (window?) at the top of the image as it distracts the views eye from the dog.   A consistent fade to black in the distance would work better (IMHO).
gunsan ( ) posted Mon, 05 May 2008 at 3:44 PM
When I paint it, I will just let the window be very faint,almost invisible.
I think I already have what I need as a start for the painting. Yes I will clone the leaf color when I paint
Thanks all for suggestions!!
danob ( ) posted Mon, 05 May 2008 at 4:25 PM
Well thats seems to have sorted that one out.. We do have a lot of expertise here well done guys
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
TomDart ( ) posted Fri, 09 May 2008 at 9:34 PM
Amen.
gunsan ( ) posted Fri, 09 May 2008 at 10:22 PM
Yes..Amen 😄
It is  painted and printed, and the receiver was happy abut it.
Thanks again guys!
