Thu, Feb 27, 1:01 AM CST
Forum Moderators: RedPhantom
Subject: Removing content tab in Poser 6?
3dz ( ) posted Fri, 13 June 2008 at 3:51 PM · edited Thu, 27 February 2025 at 12:50 AM
A few years back, I had removed the content tab in Poser 5, using a tutorial. I was wondering if there is a tutorial out there to remove the content tab and Poser 6?
From what I remember, it was something in the shell file using a text editor. It made a little difference in the speed, and I never use that tab anyhow.
wheatpenny ( ) posted Fri, 13 June 2008 at 4:36 PM
Site Admin
I'd also like to know if I can remove the content tab in P7
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
IsaoShi ( ) posted Sat, 14 June 2008 at 2:24 PM
Tried everything I could think of - all the pref / xml files, etc. - made no difference at all.
Waiting for a guru to come along...
Lutherans rule, OK!
(Izi)
Acadia ( ) posted Sat, 14 June 2008 at 2:33 PM
What is the reason for wanting to remove that tab?  I've seen people asking about that but I don't understand why because you don't get anymore room to work and it's not in the way.
IsaoShi ( ) posted Sat, 14 June 2008 at 2:41 PM
Good question, Acadia... as for me, I just couldn't resist the challenge!
LostinSpaceman ( ) posted Sat, 14 June 2008 at 2:49 PM
Removing that tab will sometimes show increased loading speed for Poser. Basically look for every entry with the word "contenRoom" in it and remove it. NetherWorks still has the PDF file online here:
http://www.netherworks-studios.com/forums/index.php?topic=2133.0
3dz ( ) posted Sat, 14 June 2008 at 6:25 PM
Thank you  LostinSpaceman,
                                                               Some people say they don't see the speed difference, but I did.  That was exactly what I was looking for.
PS. very nice site.
                                     Thanks again!
layingback ( ) posted Mon, 16 June 2008 at 4:36 PM
The speed difference is apparent if you are short on memory space (calls to IE routines), have a slower machine, and seems to be increased if you had access restrictions in place (eg. ZoneAlarm limiting access to 'Net for Poser) as Poser code likes to retry things that don't work.
But the original reason for removing it was that P5 when released was about as stable as a drunk walking the plank off a 19th century sailing galley on the high seas in a gale storm.  And with the Copy Protection code originally present, any sign of Poser throwing a wobbly could cause Interlok to crash your OS in addition to Poser, hiding all traces of the crash cause in the process.  So adding underlying IE code developed by M$ to the mix was not exactly helping!  There was a real need back then.  But it can't hurt, even now, as less code loaded should mean reduced risk.
