Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
WarKirby
To question 1... the default Poser 7 library includes a few primitives (in the Props 'Primitives' folder). You could use the cane or a cylinder (adjusted to size) until you find or make the sword you want.
Load a prop into the scene, position it in relation to a hand (for example), then with the prop still selected choose from the top menu Object --> Change parent, and select the hand from the hierarchy list. The prop will then move with the hand.
You are not able to parent both hands to a prop, or a prop to both hands. You will need to manually pose the second hand according to the position of the first hand and its child prop.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Forgot to mention something I learnt recently...
If you get a sword, for example, it might be what is known as a 'Smart Prop'. In this case, you select any part of the figure that will be holding it, load the prop, and it is automatically parented to the appropriate part of that figure (appropriate meaning whichever part it was designed for). For this reason, such smart props often come in pairs, one for each hand.
what I should be."
Murakami)
Attached Link: Blender2Poser
That's beyond me, I'm afraid, but please refer to the attached thread. Which I found by a simple search in the Forums, by the way (hint hint....) :O)"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Murakami)
I remember in another thread I made here afew months ago on a different subject, someone mentioned it was possible to use IK to link the figure to an object
Would it be possible to parent the right hand, and use IK for the left?
Adjusting manually will probably lead to strangeness and inconsistency.
The second hand can be parented to the prop (I think IK must be turned on for that to be an option) even though the prop is parented to the other hand. Before doing this, save your file. It sometimes does weird things to the hand's pose when this is done.
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
This is a small tutorial I found while browsing a while back on liking both hands to a prop. Don't know if it works as I haven't tried it but hope it helps.
Can't remember where I found it though
"LINKING BOTH HANDS TO A PROP WITH MOTION CAPTURE
This tutorial shows you how to link one hand to a prop that has been parented to another hand. An
essential technique for motion capture sequences where the imported motion capture is driving the IK
of both arms and hands. This is applicable to sequences which require both hands holding an object
such as a gun,axe, sword, staff, etc. To achieve a realistic animation, both hands need to grip the
object and not move or slide, an effect that is pretty much impossible without using the following
technique.
This tutorial includes a sample motion file in Poser .pz2 pose format, and 2 animation clips
showing Michael 3 with a rifle parented to the right hand, before and after the technique is appled.
Essentially, the objective is to parent a prop to the arm and hand which will be driven by the imported motion
capture, parent a prop to that hand, delete the keys for the other arm and hand,and link that hand to the prop.
This technique works best where the motion in the key cleared arm
isn't too extreme.
For this tutorial assume you have a motion capture BVH or pose animation of a man walking with a rifle. The effect
you want to achieve is both hands gripping and staying fixed to the rifle as he walks.
You import he BVH and parent your rifle prop to the right hand. Problem is, the left hand and arm are
driven by the motion capture and are out of sync with the motion.
[ Note: If using this technique with a .BVH file. It is advisable to import onto the character and
save as a .pz2 pose file before proceeding.]
Follow the these steps exactly as described.
1. Load character.
2. Load animated pose .In the animation palette, select and delete
all keys for both hands and fingers.
3. Load Prop
4. Adjust and pose the hands to fit the prop at frame 1
( The sample motion file already has the hands posed and aligned with the rifle.)
5. Parent prop to right hand. ( Prop will follow motion of right hand during sequence)
6.Turn on IK for left hand.
7.Select Change Parent under Object menu, and choose prop as parent.
8. Select and delete all keys for the left arm, forearm, shoulder hand etc
Wala!!
The left hand is parented to the prop, the prop is parented to the right hand."
Booked marked this. Sounds like might be useful info for later on (or when ever I get back into animating).
Poserverse The New Home
for NYGUY's Freebies
Use "phantom" prop in the middle.
I had similar problems.
Loaded any low poly primitive (for example low res ball) set ball material full transparent. Set your prop (sword, gun or sth) as a balls parent. Fix ball in correct place (on the handle?) but not change any scale. Later set ball as a hand parent.
In case you changed figure scale but your prop is still 100% scale, set figure scaling parameter on ball.
On your render ball will be invisible.
Maybe not in English but I hope clear ;)
I've been working with poser 7 for a little while, though I'd still rate myself as a beginner, I have a decent grasp of posing and using IK. I find myself presently with the need to create animations for a two handed sword.
While I could guess the sword's position in each animation, it seems like it would work a lot better if I had an approximation of it in poser to work with. I can't figure out how to do this though.
So, i have 3 questions:
