Sun, Dec 1, 4:25 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: How do I copy an object?
bagoas ( ) posted Sun, 29 June 2008 at 2:06 AM · edited Sun, 01 December 2024 at 4:06 AM
Is is in any way possible to copy or clone an object in DAZ Studio? I can copy settings, but not objects.  Did I miss something? The manual gives no clue.
B.
RHaseltine ( ) posted Sun, 29 June 2008 at 6:19 AM
No, in the case of figures. It can be done with pwReplicate for props, but each item is a new prop (it isn't an instance linked to the original)
bagoas ( ) posted Sun, 29 June 2008 at 3:42 PM
Thanks.
It is props I want to copy. Deep copy is fine.
'pwReplicate' sounds like something that can be used from scripts, not from the interface, right?
Would need to dive into scripting then, interesting, no doubt, but a step beyond what I had planned.
B.
RHaseltine ( ) posted Mon, 30 June 2008 at 9:40 AM
No, pwReplicate is a plugin so it has an inbterface for direct interaction.
retread ( ) posted Mon, 30 June 2008 at 9:51 AM
Probably a dumb newbie question:
Would it work to bring the prop into Bryce, replicate it, and then somehow bring everything back into D|S in one fell swoop?
Grateful member of....
Akhbour ( ) posted Mon, 30 June 2008 at 12:48 PM
There are no such things as dumb questions, only dumb answers, see mine! ^_^
D|S to Bryce, no probleme, Bryce to D|S=export as .obj, import into D|S as .obj and reworking all the surfaces. It is easier to use pwReplicate!
Peter
retread ( ) posted Mon, 30 June 2008 at 12:53 PM
You're funny! :D
Thanks for the reply, and I hear ya. :D I'm always up for easier. ;-)
RHaseltine ( ) posted Mon, 30 June 2008 at 3:09 PM
Actually, you could save a material preset when you loaded the single prop, then apply that to the grouped replicated OBJ version as long as your options were chosen to maintain material names.
bagoas ( ) posted Mon, 30 June 2008 at 3:51 PM
Found it.
The name of the plugin as sold on DAZ is actually just 'Replicate', without the 'pw', and it sells there at $9.95; not what I had in mind either.
B.
