Thu, Dec 12, 9:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
Subject: Getting what I see?
WarKirby ( ) posted Mon, 07 July 2008 at 9:48 PM · edited Thu, 12 December 2024 at 9:49 PM
I've been wondering for a while why the feet in my animations are sliding on the ground, when they're perfectly planted within poser.
Until someone nicely pointed out that IK gives false results. When I export as bvh, I get what I see if IK is turned off, not with it on. This is annoying because I can't think of any other way to make the feet stay perfectly in place when they're not supposed to move.
Does anyone have any suggestions on how I can make my animation actually look like what it appears to be with IK enabled on the legs?
markschum ( ) posted Mon, 07 July 2008 at 11:33 PM
I use multiple keyframes with break spline to stop spline interpolation of the foot position once its on the ground .
Acadia ( ) posted Tue, 08 July 2008 at 2:32 AM
What I do  first  after posting the figure is to identify which leg is the weight bearing one.
Then I go back to frame 1 and look at the figure from the side while moving the slider to the right, paying attention to the weight bearing leg.
Depending on which direction the foot slid, I go back to the frame where I set the pose and then use the Z Trans dial to either move her a bit forward or a bit backwards to compensate for the sliding.  If the figure slid backward, I move the Z Trans dial to the right to move the figure a bit forward. If the figure slid forward, I move the Z Trans dial to the left to move the figure a bit backwards.
I then go back to frame 1 and move the slider to the right to see who I've done and if I need to adjust the Z Trans dial further. Once I am happy with the front/back movement, I do the same for the side movement.
This time I look at the figure's feet from the front and doing the same thing as I did above, I adjust the movement using the X Trans dial.
Before I render I make sure I go back to the keyframe window and delete the frames from the main camera just in case I've messed it up along the way.
WarKirby ( ) posted Tue, 08 July 2008 at 3:08 PM
Someojne told me using translate on body parts is a very bad idea.....
Can yuo expain more about breaking splines? I know how to do that, but I'm not sure which parts it should be done to
lesbentley ( ) posted Thu, 10 July 2008 at 3:13 AM · edited Thu, 10 July 2008 at 3:14 AM
Try this. Compose your animation with IK on, give the feet a keyframe in all frames. Run the animation once (not sure if this is necessary), then turn IK off. If you now run the animation, I think you will find that the position of the feet has been remembered, even though IK is now off.
WarKirby ( ) posted Fri, 11 July 2008 at 9:12 AM
That's an awesome idea, les. Thank you.
Something like that will kind of inhibit farther editing though, so I guess I'll have to do that just before exporting.
