Fri, Nov 29, 8:30 AM CST
Subject: Looking for a few things
Mesh_Magick ( ) posted Sun, 24 June 2001 at 11:16 PM ยท edited Fri, 29 November 2024 at 6:42 AM
looking for kung fu poses,Baggy pants that fit the p4 male and a DAZ Oriental Male texture with Dragon tatoos, I have the template but its low rez and not very good for the detail I think Im looking for in the Dragon tatoos. Also looking for a bump map for the soles of the p4 male sneakers.
Mesh_Magick ( ) posted Sun, 24 June 2001 at 11:33 PM
motion blur added
Mesh_Magick ( ) posted Mon, 25 June 2001 at 12:24 AM
found dragon still looking for poses and a good Oriental male texture.
hauksdottir ( ) posted Mon, 25 June 2001 at 1:10 AM
OK, there have been several tattoo textures posted over the last 6 months. search under tattoo and you should spot most of them. There are a few oriental males, with the right texture, around. The oriental sites are the best place to start looking (go to Digital Babes and check the links). Schlabber did a bunch of Kung Fu poses, if my memory is correct. I'd check his site first for any sort of pose. Carolly
Mesh_Magick ( ) posted Mon, 25 June 2001 at 1:43 AM
whats his site url? thanks:)
Mesh_Magick ( ) posted Mon, 25 June 2001 at 1:47 AM
The motion blur by the way was added in useing motion blur in paint shop pro 6
Tamela.J. ( ) posted Mon, 25 June 2001 at 3:11 AM
Attached Link: http://schlabber.critical-depth.net/index.html
Heres the URL http://schlabber.critical-depth.net/index.html Tamela
Dal ( ) posted Mon, 25 June 2001 at 1:27 PM
Attached Link: http://morphs.bbay.com/
Trav did a load of morphs for the p4 male pants check out morphworld look under "Downloads" then "Misc Morphs". Its called Male Combat Pants - I think you should be able to make what you need out of those :) All the best, Dal
Mesh_Magick ( ) posted Mon, 25 June 2001 at 4:58 PM
Thanks, for the urls, Ill see if I find the oriental male texture at poser factory or one of those links.
Mesh_Magick ( ) posted Mon, 25 June 2001 at 6:56 PM
Ok I did not find the Kind of Kung Fu poses I was looking for, I guess Ill have to make some More Flying Dragon Poses then.
hauksdottir ( ) posted Mon, 25 June 2001 at 7:55 PM
OK, but you are finding some of what you need through the links, and can maybe tweak the rest. With all those martial ars schools, finding the exact "Drunken Dragon Jab" or "Waltzing Tiger Wheel Kick" would be tricky anyway. Carolly
