Fri, Nov 29, 1:07 PM CST
Subject: How do you add poser 7 runtime to poser pro runtime?
Zanzo ( ) posted Fri, 05 September 2008 at 12:59 PM · edited Fri, 15 November 2024 at 10:17 PM
Do I have to copy my entire poser 7 runtime folder to the poser pro folder or is there a way to import in poser pro?
I'm trying to open a poser 7 project file with poser pro and now it's looking for a bunch of files that are in the poser 7 runtime.
Zanzo ( ) posted Fri, 05 September 2008 at 1:22 PM · edited Fri, 05 September 2008 at 1:33 PM
Guys I have one more problem with poser pro.
For some reason it is rendering a lot slower than poser 7.  I'm using the exact same firefly settings and during the render on poser pro the cpu usage is at like 3-4%, which takes like 2 minutes to render the whole scene ....  The same exact scene in poser 7 renders super fast, like 10-15 seconds.
Man this sucks. I hate beta testing. :(
UPDATE: the service pack didn't help at all.
silverthornne ( ) posted Fri, 05 September 2008 at 2:36 PM
I know the render engine always default to fixing gamma and hdr output. Remove those and check if it helps; I just haven't used Pro enough to confirm these items helping but it's worth a shot.
Zanzo ( ) posted Fri, 05 September 2008 at 2:51 PM
I checked off HDR output and gamma. Even with both of those settings off I can't get the background renderer to work.  Nor can I get the default firefly renderer to render as fast as poser 7.
Zanzo ( ) posted Fri, 05 September 2008 at 3:36 PM · edited Fri, 05 September 2008 at 3:39 PM
Ok I got the background renderer to work. I'm not impressed with the speed improvement  but oh well.
Anyways I appreciate your help guys! Thanks so much.
cspear ( ) posted Sat, 06 September 2008 at 5:51 AM
Quote - Ok I got the background renderer to work. I'm not impressed with the speed improvement  but oh well.
You are using this on a 64-bit OS (WinXP 64 or Vista 64) .....aren't you?
PoserPro 11 - Units: Metres
Adobe CC 2017
