Scarab, you may need to work with the 'Spew4You'. You can get good liquid effects if you spend some time with it. Bloodsong - Why would you need a utility for that? You mean like when you are using magnets and you do one side of the face and you want a mirror of that on the other side? Here's a simple shortcut: Add your additional magnets and set them to mirror the first magnet(s) settings. Usually it's the same amount in the opposite direction. That sounds like common sense, but there's been a lot of 'DOH!'s around here lately. ;-) Or did you mean in like Max or RDS? I can't offer any help there, sorry. Newc
scarab: that was codeman, wasnt it? newc: no, i mean real morphs, not magnets. :) like if you make a one-sided sneer, and then want to make a left-sided sneer. for people using ray dream/max/amorphium/nendo/etc and/or who are 'magnetically challenged.' or if you transform the left arm into... something complicated, like a three pronged tentacle with pincer claws that you can't do with a magnet. and want to have the right arm automatically generated for you.
Attached Link: (View my Projects at my Gallery.)
... that utility that would make symmetrical facial morphs, or swap left and right sides of morphs, by reading the X values and switching them from positive to negative and vice versa? who was working on the p4 snake, adding sections? you're right, it needs more sections... and the curve parameter on them would've been helpful, too!
