I use CRPro II on a regular basis.
You'll have to tell CRPro where to find your Poser installations first. It seems it looks for a Poser.ini file and expects it to be in the folder above the main runtime - which is no longer true for Poser 7 and higher.
You can include runtimes in the upper right pane. Once you've added those runtimes AND selected a runtime subfolder in the upper left pane, the reference check options will become available.
Okay, I think I've got it now. It seems that external runtimes are automatically added but not automatically selected. This wasn't clear from the help file. I thought it was all automatic. Once I doubleclick and checkmark the runtimes in the upper right panel it seems to work. Thanks for the advice.
Not strictly a Poser question, sorry, but has anyone gotten CRPro II to work? I bought the full version before Christmas and when I installed it seemed to upgrade a trial version of CRPro that was already on my drive. It worked fine but I wanted it in a different folder so I uninstalled everything. After reinstalling it doesn't work. It seems that none of the reference checks are enabled and the option to enable them is greyed out. As a result, the program finds no problems with files I know are faulty.
I've tried:
Nada, nothing works. Am I missing something? It shouldn't be this hard to get a program working. I've sent a couple support emails but haven't had a response. Figured I'd try my luck here in case anyone has had a similar problem. Thanks.
