Sat, Nov 23, 2:27 PM CST
Subject: CRPro II
jal ( ) posted Fri, 09 January 2009 at 8:09 PM · edited Sat, 10 August 2024 at 1:23 AM
Not strictly a Poser question, sorry, but has anyone gotten CRPro II to work?  I bought the full version before Christmas and when I installed it seemed to upgrade a trial version of CRPro that was already on my drive.  It worked fine but I wanted it in a different folder so I uninstalled everything.  After reinstalling it doesn't work.  It seems that none of the reference checks are enabled and the option to enable them is greyed out.  As a result, the program finds no problems with files I know are faulty.
I've tried:
  • multiple uninstalls/installs with reboots in between
  • deleted 'Application Data/hogsoft 3d' folder before a new install
  • upgraded to the patched version from the hogsoft Forum
  • checked registry for old entries
Nada, nothing works.  Am I missing something?  It shouldn't be this hard to get a program working.  I've sent a couple support emails but haven't had a response.  Figured I'd try my luck here in case anyone has had a similar problem.  Thanks.
markschum ( ) posted Fri, 09 January 2009 at 10:06 PM
You should use site mail to Hogwarden here at renderosity. He should be able to help sort it out.
svdl ( ) posted Sat, 10 January 2009 at 10:30 AM
I use CRPro II on a regular basis.
You'll have to tell CRPro where to find your Poser installations first. It seems it looks for a Poser.ini file and expects it to be in the folder above the main runtime - which is no longer true for Poser 7 and higher.
You can include runtimes in the upper right pane. Once you've added those runtimes AND selected a runtime subfolder in the upper left pane, the reference check options will become available.
My gallery   My freestuff
jal ( ) posted Sat, 10 January 2009 at 12:48 PM
Okay, I think I've got it now.  It seems that external runtimes are automatically added but not automatically selected.  This wasn't clear from the help file.  I thought it was all automatic.  Once I doubleclick and checkmark the runtimes in the upper right panel it seems to work.  Thanks for the advice.
