Wed, Feb 26, 7:42 PM CST
Forum Moderators: RedPhantom
Subject: Anyone know AO well enough to help me out? Poser 7
  • 1
  • 2
dasquid ( ) posted Tue, 27 January 2009 at 5:10 PM · edited Wed, 26 February 2025 at 7:41 PM
 I have been working on this render since last night. I decided to try to learn how to use the AO lights that are in Poser and  I like some of the results but  not others. The first time I rendered this there was a dark black outline around her and even around the brow transparency making it  completely visible. the second render  after turning down the AO on the light, there are very strange dark marks  under her right elbow, across her right collarbone/shoulder area and  her left elbow and hand.
(also if anyone could help me out with making her eyebrows look better I would appreciate that too, Im trying to use transmapped brows since the texture actually doesnt have those damned painted on brows lol)
dasquid ( ) posted Tue, 27 January 2009 at 5:19 PM
I am not sure what the settings were on the first render but on the second render the AO strength was 0.570001 and the light type was a diffuse IBL with no shadows.
Before anyone makes fun of me  and says LOL Yer doin it wrong, I'm asking because I don't know how lol. anyway the second render (posted in this post) got rid of the crap under her elbow but leaves some at her shoulder area and her left elbow and hand.
JenX ( ) posted Tue, 27 January 2009 at 5:24 PM
Hey, dasquid.  Do you have a screenshot of your light settings?
dasquid ( ) posted Tue, 27 January 2009 at 5:30 PM
just the AO light?
JenX ( ) posted Tue, 27 January 2009 at 5:30 PM
Well, actually, how many lights do you have in your scene?
svdl ( ) posted Tue, 27 January 2009 at 5:33 PM
Light based AO is too much a "one size fits all" type of solution - which almost never works.
You're better off with material based AO. For example, you DON"T want AO on those transmapped eyebrows, but you DO want it on the stones of that flor, and probably on the skin of her body.
The AO strength on materials should be set about 10 times as high as on lights to get a comparable effect, that's some weirdness that's built into Poser.
You'll also want some shadow and some specular effects.
IBL is great for setting the overall lighting of your scene, but you need additional lights for specular effects and shadows. This looks like an outdoor scene, so I'd suggest adding an infinite light for "sunlight" and shadows, toning down the IBL light strength a little, and maybe an extra light with Diffuse color set to black, Specular to white, no shadows, to bring out some extra speculars.
My gallery   My freestuff
dasquid ( ) posted Tue, 27 January 2009 at 5:37 PM
Quote - Well, actually, how many lights do you have in your scene?
Just 2 lights  one the sunlight which is a large spotlight casting shadows and the IBL light that has the AO turned on
dasquid ( ) posted Tue, 27 January 2009 at 5:41 PM
Quote - Light based AO is too much a "one size fits all" type of solution - which almost never works.
Material based AO? thats in the material room on the right?   lol I can use all the help I can get with lights I can get good lights and shadows sometimes but then other times it takes me longer to do the lights than it does to get the scene built.
JenX ( ) posted Tue, 27 January 2009 at 5:50 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2717720
BagginsBill has a great in-forum discusion on AO in this thread.  I usually end up using the material-based AO over the light-based, it usually comes out nicer, in my experiencs.  Though, YMMV. ;)
dasquid ( ) posted Tue, 27 January 2009 at 6:23 PM
Thanks for the link Ill have a look at it but Ill ask questions here since that thread is  two years old.
JenX ( ) posted Tue, 27 January 2009 at 6:23 PM
No probs :)
hborre ( ) posted Tue, 27 January 2009 at 6:25 PM
Actually BB reversed himself on the material-based AO issue based on trials using PoserPro.  Another post in the forum suggests stripping out the VSS Prop of all AO nodes and going with the light-based AO renders.
But I do agree with svdl, the key to a great scene is lighting.  Even using minimal setup, you can render the most spectacular images imaginable.
dasquid ( ) posted Tue, 27 January 2009 at 6:51 PM
Quote - Actually BB reversed himself on the material-based AO issue based on trials using PoserPro.  Another post in the forum suggests stripping out the VSS Prop of all AO nodes and going with the light-based AO renders.
Im not sure what Vss is  and is that reversal only in poser pro? because I am using Poser 7
bagginsbill ( ) posted Tue, 27 January 2009 at 7:11 PM · edited Tue, 27 January 2009 at 7:12 PM
The key to great lighting is Gamma Correction.
The key to great AO may still be material-based AO.
But - Poser 7 SR3 and Poser Pro have improved the light-based AO a lot. But still not as good as material-based. If you have not installed Poser 7 Service Release 3 (SR3) then I'm going to stop you right there. Either install SR3, or don't do light-based AO.
With light-based the good news is you only have one set of parameters to adjust. The bad news is you only have one set of parameters to adjust. No that's not a typo.
If you can find settings that work for every item in your scene, light-based is better/easier as there is less to adjust. However, you can get into situations where one scene area demands that you increase a parameter to get it to look right, and another scene area demands that you decrease that same parameter to get it to look right. When you hit one of these contradicting requirements, your only recourse is to abandon the light-based AO.
The black spots (artifacts) are almost always an indication that you need to increase the bias on the AO. However, before you go raising it to a really high number, understand that it will prevent AO from appearing in any geometric feature that is smaller than the bias.
So if you set the bias to .5 inches, then the nostrils, which are less than that, will no longer experience AO, and you will get "nostril glow". Small crevices, like the armpit crease, will lose the AO in the deepest part, but suddenly just outside, it will turn on.
These are the situations you end up in. Raising bias to remove spots, lowering bias to reach into tiny creases.
I'm still not certain that light-based AO actually performs as well as material based. Last couple days, I had a situation where I could not get the AO shadow to look right in a crease.
bagginsbill ( ) posted Tue, 27 January 2009 at 7:15 PM
Your first problem is your IBL is too even. There is too much light coming from below.
What image are you using to control the lighting in your IBL?
dasquid ( ) posted Tue, 27 January 2009 at 7:59 PM · edited Tue, 27 January 2009 at 8:01 PM
Quote - Your first problem is your IBL is too even. There is too much light coming from below.
Hmm my version of poser 7 is 7.0.2.127 I'm assuming that that is  Sp2 then?
and the best AO is lighting based but only with SP3?
bagginsbill ( ) posted Tue, 27 January 2009 at 9:33 PM
The best AO is material based in all versions.
Prior to SP3, light-based AO was so inferior as to be unusable.
It is now better than it used to be, but I'm not certain its the equal to material-based AO.
In any case, if you find there is no value for the bias that works for your whole scene, then it has to be material-based AO.
bagginsbill ( ) posted Tue, 27 January 2009 at 9:36 PM
You didn't show me the IBL image you're using. What I'm saying is you need one like this. In fact, try this.
The amount of light from the sky is like 10 times what comes bouncing up from the ground.
If you're doing an outdoor daylight render, this is the type of image you need to use.
dasquid ( ) posted Tue, 27 January 2009 at 10:17 PM · edited Tue, 27 January 2009 at 10:19 PM
> Quote - You didn't show me the IBL image you're using. What I'm saying is you need one like this. In fact, try this. > > The amount of light from the sky is like 10 times what comes bouncing up from the ground. > > If you're doing an outdoor daylight render, this is the type of image you need to use.
Sorry I forgot i am trying to  figure out all this stuff and I keep getting distracted and losing my place lol. but this is the one I used and if i had looked closer i would never have used it since it seems that all the outdoor ones i have have friggin cars in them even if  you cant see them in the thumbnails.
Edit: sec damned thing is too big got to shrink it a bit.
here we go
bagginsbill ( ) posted Tue, 27 January 2009 at 10:55 PM · edited Tue, 27 January 2009 at 10:55 PM
Well it doesn't matter that there's a car in it. I could put my face in it and you'd not notice it. The details don't matter. It's the broad swaths of color and luminance that matters. This image controls diffuse reflection only, so that means that hundreds of points contribute to the illumination from any given direction. Effectively, the image is blurred beyond all recognition of details like tree branches or cars or street signs.
What does matter is that whoever made that doesn't understand the angular map format. First of all, a mirror ball is not the right format. A mirror ball, unless shot from infinitly far away, doesn't include much information from behind the ball.
Second, it was shot while looking down. As a result, a good part of that image showing the sky is actually being used to illuminate the subject from underneath and in front of the figure. Imagine I took a big light and put it in front of you on the ground and shined it up into your face. Equivalent to all the light that is just above the car. That's what is happening here.
The third thing that's wrong with it is it is a normally colored photo. Which means the color information is recorded to look like real life when viewed on your computer screen. This is the sRGB color space, and it inflates illumination intensities. A properly made IBL light probe is encoded not in sRGB color space, but linear color space. What this means is that the information Poser gets from this image is not only positioned incorrectly, but grossly over bright.
You won't get any decent contouring from such an image. It's basically the equivalent of several hundreds really bright light bulbs arrayed in front of and under your subject.
Throw that away.
bagginsbill ( ) posted Tue, 27 January 2009 at 11:00 PM
Here, I converted it to linear color space. That should get you some improvement just to get started.
bagginsbill ( ) posted Tue, 27 January 2009 at 11:03 PM
Here's another better version. I darkened all the parts that come from below the subject.
This should work pretty well now.
bagginsbill ( ) posted Tue, 27 January 2009 at 11:14 PM
Here is a figure lit with the original IBL image you were using at 100%, along with a single infinite light at 70%.
Everything is blown out. Too much light.
bagginsbill ( ) posted Tue, 27 January 2009 at 11:15 PM
Here I substituted the doctored version I gave you. Much better.
dasquid ( ) posted Tue, 27 January 2009 at 11:31 PM
Wow thats a hell of a difference. That image actually came with poser 7 and all of the ones that came with it are made that way.
I am rendering it now with the  image you posted at first after changing a few things with the lights mainly positioning and changing out the IBL image.
dasquid ( ) posted Wed, 28 January 2009 at 2:53 AM
Well the render finally finished.and here it is the only difference between this and the last is I changed the IBL image to the one you posted at first and the sunlight shadow spotlight I just moved it to point at her instead of pointing at her head it pointsat her from the viewers right.
shedofjoy ( ) posted Wed, 28 January 2009 at 3:56 AM
I tried SR3 but the 100% processor bug inflicted my system so i had to uninstall and reinstall P7 with SR2....if someone knows why this bug happens and how to avoid it, or maybe someone somewhere is gonna release SR4 that fixes this so i can have a better P7,lol
Getting old and still making "art" without soiling myself, now that's success.
AnAardvark ( ) posted Wed, 28 January 2009 at 9:49 AM
In the RDNA forums (somewhere) there is a really nice discussion of IBL and someone (Traveller?) posted a shader setup and set of masks he uses. Basically, you create an IBL sphere which has left, right, front, back, upper, and lower areas. You can vary the color and intensity of all these areas through the inputs to the nodes. You can use it then to give a directionality, and even color to the IBL, which can give you some really nice effects.
bagginsbill ( ) posted Wed, 28 January 2009 at 1:08 PM
Attached Link: IBL Ins and outs by Olivier on 01/07/06
It was Olivier.
bagginsbill ( ) posted Wed, 28 January 2009 at 1:10 PM
Quote - Well the render finally finished.and here it is the only difference between this and the last is I changed the IBL image to the one you posted at first and the sunlight shadow spotlight I just moved it to point at her instead of pointing at her head it pointsat her from the viewers right.
For sunlight, where is extremely far away, all the light rays are essentially parallel. The correct type of Poser light to use for this purpose is a Infinite light. A spotlight has a specific location where the rays originate from, as well as having a cone which modules and limits the illumination.
For an outdoor simulation, don't use a spotlight. Use one IBL and one Infinite.
bagginsbill ( ) posted Wed, 28 January 2009 at 1:14 PM
I still don't see shadows.
When learning the lighting ropes, I think it is really important that you work with a single light at a time, until you understand what it is doing when you change things.
You should turn off all but one light. Work with that light until you understand what it is contributing. For example, start only with IBL. Get the AO correct for that.
Then work with the next light which would be your Infinite. Turn off the IBL and all shadows. Render with the infinite. Then turn on shadows and render again. Observe the shadows carefully.
Then turn on both and render with them together. Adjust levels, keeping in mind what you learned from the individual renders. The final render from both will be more than the sum of the parts, however, because gamma correction will come into play.
Trying to manage all these light effects together is dangerous until you understand what each light (and light type, and shadow type) is doing by itself. It's like trying to make an arrangement for a Symphony, and you don't really know yet what the tonal difference is between a Violin and a Viola and a Cello.
dasquid ( ) posted Wed, 28 January 2009 at 5:50 PM
Quote - > Quote - Well the render finally finished.and here it is the only difference between this and the last is I changed the IBL image to the one you posted at first and the sunlight shadow spotlight I just moved it to point at her instead of pointing at her head it pointsat her from the viewers right.
Ok that makes sense but I have found that I have trouble getting proper shadows with infinite lights and no spot.
dasquid ( ) posted Wed, 28 January 2009 at 5:57 PM
Ok which light should have the shadows? the IBL or the sunlight? also if i am going to have to do so many test renders I think Ill have to cut everything but the lights back to basic settings because if i dont it would take hours to do several test renders lol.
hborre ( ) posted Wed, 28 January 2009 at 6:46 PM
There is no option for shadows on IBL.  You would like your shadows on Infinity lighting which, for daylight, is your primary light source.  For test renders, set back your settings but not so far back that raytracing suffers.  Once you work out your lighting for the scene, then scale up your settings for the final render.  Remember, you are only working with 2 lights.  The renders should go quickly.
dasquid ( ) posted Wed, 28 January 2009 at 8:26 PM
Quote - There is no option for shadows on IBL.  You would like your shadows on Infinity lighting which, for daylight, is your primary light source.  For test renders, set back your settings but not so far back that raytracing suffers.  Once you work out your lighting for the scene, then scale up your settings for the final render.  Remember, you are only working with 2 lights.  The renders should go quickly.
Maybe they should go quickly with only two lights but the last render i posted took a couple of hours to render and it only had two lights. I only have an AMD 2800+ for a processor and only a gig and a half of ram.
bagginsbill ( ) posted Wed, 28 January 2009 at 8:59 PM
A couple hours!?! I don't have anything that takes a couple hours. Hmmm. Even if I assume your processor is 4 times slower than my laptop (which it isn't) you should see nothing longer than 10 minutes for the kind of render you are doing. You have no refraction or reflection that I can see,which are the usual killers.
What version of Poser, and service release?
What are you render setting, light settings, shadow settings, etc.
I can do a render like you produced in less than a minute.
hborre ( ) posted Wed, 28 January 2009 at 9:40 PM
I agree with BB, couple hours is excessive for a simple scene.  Unless there is more to the scene we are not seeing.  Your background appears to belong to a scene set which means that you will have additional objects and props placed about.  If that is true, Poser will try to render everything regardless whether you see it in your camera view or not.  I would suggest you switch to your Auxiliary camera and identify every prop on the set.  Determine if the props are necessary to the scene and either delete them or make them invisible.  This is an inherent problem with Poser.  The more props and objects present and unseen adds to the render time.
dasquid ( ) posted Wed, 28 January 2009 at 9:48 PM · edited Wed, 28 January 2009 at 9:49 PM
> Quote - A couple hours!?! I don't have anything that takes a couple hours. Hmmm. Even if I assume your processor is 4 times slower than my laptop (which it isn't) you should see nothing longer than 10 minutes for the kind of render you are doing. You have no refraction or reflection that I can see,which are the usual killers. > > What version of Poser, and service release? > > What are you render setting, light settings, shadow settings, etc. > > I can do a render like you produced in less than a minute.
You must have one hell of a computer lol
Poser 7 version 7.0.2.127
dasquid ( ) posted Wed, 28 January 2009 at 9:51 PM
guess i need another post for another  screenshot
ice-boy ( ) posted Thu, 29 January 2009 at 3:39 AM
turn of displacement in the rendering setting. min shading rate should be 1 or 2 for teste renders.
pixel samples 7? 3 for test renders.
IMO of course.
dasquid ( ) posted Thu, 29 January 2009 at 6:05 AM
Quote - turn of displacement in the rendering setting. min shading rate should be 1 or 2 for teste renders.
IMO of course.
Well I am currently doing a test render with   raytraced shadows and everything else turned down to the minimum settings and it is still taking  a hell of a lot longer to render than the 1 minute quoted by BB lol I dont have a clue why my renders are going so slow. the longest render i have ever had was 26 hours. and that was a royal pain waiting on my computer for that long lol.
hborre ( ) posted Thu, 29 January 2009 at 6:09 AM
Did you re-examine the content of your scene?  As stated before, if you have too many props in the scene that are not in camera view, they add to the render time.
dasquid ( ) posted Thu, 29 January 2009 at 6:23 AM
Quote - Did you re-examine the content of your scene?  As stated before, if you have too many props in the scene that are not in camera view, they add to the render time.
The only things in the scene are the ground plane the pillar the wall and V4.
hborre ( ) posted Thu, 29 January 2009 at 6:38 AM
It almost sounds like the scene might be texture intensive and a possibility that the displacement setting might be slowing down the render.
Check your material room settings for your scene and determine if a displacement map is needed.  With such a detail level on your background, I wouldn't be surprised that there is one.  While in the material room, change the Texture Quality to None on the Image_Map.  In your render settings, uncheck displacement and re-render to determine how fast is your turnover.  If no difference, then systematically make each part of your scene invisible and again render.  Doing this will isolate where the problem is occurring.  A highly detailed texture map will cause your system to slow down considerably.  Happened to me once on a slower machine.
ice-boy ( ) posted Thu, 29 January 2009 at 7:23 AM
Quote - > Quote - turn of displacement in the rendering setting. min shading rate should be 1 or 2 for teste renders.
IMO of course.
26 hours is so unrealistic that i can not even belive you.
dasquid ( ) posted Thu, 29 January 2009 at 8:37 AM
Quote - > Quote - > Quote - turn of displacement in the rendering setting. min shading rate should be 1 or 2 for teste renders.
IMO of course.
Believe it or don't but this
http://www.renderosity.com/mod/gallery/index.php?image_id=1713311
is the render that took 26 hours
bagginsbill ( ) posted Thu, 29 January 2009 at 8:51 AM
Aha - your min shading rate is way too aggressive. I'll explain later when to set it that low, but .07 is going to really slow you down.
Set it to 3 and see what happens. That's not a good setting for a final render, but it is good for a test render.
Then set it to 1 and see what happens.
There are occasional good reasons to go below 1, but such things should be handled with thought and care, not as a matter of course, and certainly not for test renders when you're trying to learn lighting.
hborre, what you said about things outside the scene being rendered as well is not correct. They do contribute to other calculations, such as shadows, and reflections, but the actual rendering of those objects does not happen.
In any case, that's not the issue here.
bagginsbill ( ) posted Thu, 29 January 2009 at 8:53 AM
Also Pixel Samples = 7 is too high for test renders, and even for final renders, on a computer like yours. The tiny difference between 3 and 7 is not worth the time for most renders.
Set it to 1 for a lighting test. Use 3 for a good draft render.
Also your bucket size at 128 is good for speeding up if you make all the other settings light-weight as I describe. However, if you're going to run out of memory, it will kill you. So you should be using 32 when you do final renders.
bagginsbill ( ) posted Thu, 29 January 2009 at 8:55 AM · edited Thu, 29 January 2009 at 8:55 AM
You showed me the IBL outer settings, but not the actual AO values.
This will affect speed - I need to see those.
bagginsbill ( ) posted Thu, 29 January 2009 at 8:56 AM
What is your Poser Display Unit set to? (Inches, feet, etc.)
dasquid ( ) posted Thu, 29 January 2009 at 9:00 AM
Quote - What is your Poser Display Unit set to? (Inches, feet, etc.)
I set it to inches after reading a few things last night also the AO settings where the heck do I get them lol I thought that was them lol
  • 1
  • 2
