Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
have you got it set on dynamic population? its a little button to the side which when selected creates the ecosystem when the picture renders and so shows a count of 0.
Rich
http://blog.richard-potter.co.uk
can you put some screen dumps of your material setting please and perhaps also the scene? that would probably be most helpful to everyone.
Rich
see if you have "Decay near foreign objects" ticked in the density panel. Remove the tick and try again
My Freebies
Buy stuff on RedBubble
There is an altitude control for the eco in the environment tab. Just move the slide so the minimum doesn go all the way to -1 on the left. The exact value depends on your terrain, a few trials will lead you to the right choice.
The 'decay' option helps you avoid populating areas where there is already an object. Eg you have a house in your scene, you wouldnt want the trees to grow through the house so you turn on this optins and the tree population will decrease as they get close to the house.
"I paint that which comes from the imagination or from dreams,
or from an unconscious drive. I photograph the things that I do not
wish to paint, the things which already have an
existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
I´m new at VUE 7, a simple question, I create terrain, and after that i choose "Forest and green fields" as ECO system. But when I edit ECO system and choose populate I do not get any instances, It says 0 ? What am i doing wrong?
