Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Its probable too Small for Wing to see it...
Try loading and scale it 5000 times in poser and then export it..
But the No edges polys etc etc seems to be a game breaker for my idea..
But just try it scale 5000 times... and see
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Tried doing that with hexagon and got a read error whenever I loaded it. I'm guessing the .obj is corrupted somehow so not everything can read it.
One other thing: I was poking around the geometries folder in poser and there are two torii listed. Maybe that is part of the problem.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
The torus.obj as exported has "fo" lines instead of "f" lines. After I
edited the file to make them all "f" lines, it showed up properly in Amapi.
From the official Wavefront OBJ format:
NOTE: Any references to fo (face outline) are no longer valid as of
version 2.11. You can use f (face) to get the same results.
References to fo in existing .obj files will still be read,
however, they will be written out as f when the file is saved.
My python page
My ShareCG freebies
How did you get the FO lines again? After running it through another modelling app?
My python page
My ShareCG freebies
Yes, that makes sense. The original obj (TorusThin.obz) has
the FO lines, so Poser just copies them on export.
After changing them to 'f' lines, other applications will accept the OBJ.
My python page
My ShareCG freebies
Quote - Load the "Torus" prop from the Primitives Folder in the Props Library
Export the Torus to a Wavefront OBJect file named "Torus.obj
So there are two answers to above question:
I think nobody expected this:)
Yes. Poser's import/export functions haven't been modernized in newer
versions..... they are basically the same as in version 3.
My python page
My ShareCG freebies
Thank you all for your speedy responses.
Come to think of it, I had this same problem several years ago and had completely forgotten about the solution.
Thanks again.
Please make notes about this solution so when I ask this question again in 2-3 years, you'll have the answer ready. :lol:
cheers,
dr geep <------------------------- feelin' kinda stoopid :sad: ... needs to up the memory pills, too.
cheers,
dr geep ... :o]
edited 10/5/2019
oh...I thought we'd discovered an interdimensional object...;) I've had strange things happen when importing objects from one program to another. I'll have to remember that stuff...thanks all (Pakled is not smart...;)
Here's the situation:
In Poser:
Open Wings 3D and Import the Torus.obj
......... Now the mystery ................
The Torus appears in the list of objects in Wings but has 0 polygons, 0 edges, and 0 vertices,
and is not visible !!!!!!!!!!!!!!!
Why ??????????????????????????????????????????????????????
Note - The Torus.obj shows up normally when Imported to Carrara and UVMapper.
Anyone? ..... Anyone? ..... Anyone? ..... Bueller? ..... Bueller? ..... Anyone? ..... Anyone? :blink:
cheers,
dr geep ... :o]
edited 10/5/2019
