Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Not sure I understand what you mean. You can't open Vue anymore?
What window says Sendlog.exe?
The sendlog.exe is the automatic error report Vue launches after a crash so you can send a report to e-on. The report contains the text you will enter in the error report's window, and an automatic crash log that was created after the crash.
I think the error log is generated by VUE, just like hein said. As It is now I can only start VUE one time after system restore. Second time I start, I end up with the same message again. I have found SendLog.exe in two folders, but I can´t do anything with them. Sometimes two error dump files are created, but even if I delete them I end up with same problem.. Maybe there are some way to disable the error report from within VUE ?
I use Vista Home 64-bit, I get occasiounally error when I close program. But now I can´t start at all It says SendLog.exe error ? Any idés
