Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 6:08 pm)
is that last "{" part of your file? That might be causing a problem. Everything else I see is pretty much the same as MATs I've made...
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
There is also an extra { just after the word 'figure' near the top.
You should go through and count the brackets, or use an
editing app that can automatically check bracketing.
My python page
My ShareCG freebies
My python page
My ShareCG freebies
Awesome, Ockham! I'll try that one immediately.
I'm using Notepad++ for the checking. It usually lights up solitary brackets.. not here though. I'll test your file to see if it was a copy error or what ^_^
I'm starting to wonder if it's my M4 that is odd. I have problems with some of the MAT poses from Daz as well, they won't load onto him properly. He's also prone to crashing my Poser, requiring a full reboot before I attempt to load him again :(
The X-file didn't work either, but again it may be something on my puter and not the file itself.
I'll start counting brackets and see if they match up ...
And thanks for the help. Even if it didn't work in this case. I guess I need to figure out if it's my installation or what that is causing it. I'll see how it looks in Poser 6 first of all...
I haven't heard of Komodo. But Notepad++ is a far cry from a mere Notepad application. It's perfect for somethinglike this, also because you can do a global search-and-replace on a whole LOAD of files in one go with it.
But I'll take a look at Komodo all the same :) I was sceptical about Notepad++ until I trid it, too L
"NO_MAP" <-- I would remove these "" thingies from No_MAP, they do not belong there. Some Poser versions might through out an error message about not being able to find the NO_MAP texture.
Why don't you make partial material poses with Poser 7 - at least they would be correct. I've seen some weird stuff in mat poses done with Shader Spider like duplicate texture nodes in the material room for example.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
I would load up the textures in Poser 7 and save a material collection. I believe that can be selective in what materials get saved. Then convert the mc6 file to a pz2 in wordpad , and maybe compare the two files.
here is the start of amat pose file
version
number 7
figure
material 1_EyeSocket
KdColor 1 1 1 1
two { after figure is wrong.
Partial poses don't work for node based materials (never have, using PZ2s, MT5s or MC6s makes no difference).
If you need to make changes to node based materials, you either have to do it either with a Python script or via ShaderSpider's own mechanism (which requires at least the free ShaderSpiderLE to apply them).
Ah lovely. An update that breaks things :(
Anyway, in the meantime I've found a much easier way to do Partial MAT files: Save an MC6 with only the materials you want to change, then change "mtlCollection" into "figure" and rename the lot to pz2.
Please, I'm at my wit's end.
I've been making partial MAT poses, with ShaderSpider™ as so many times before. The major difference is it's my first time for M4.
Anyway... For some obscure reason, the MAT poses doesn't work. They don't do ANYTHING at all. And I can't figure out WHY.
So.. if someone could take a quick gander on this and perhaps spot the error?
This particular one is an EYE MAT, and this is the Poser 5 version, those usually work fine in Poser 7.
And the location of the textures is correct, too. The ""'s should be there, right?
version
number 5
figure
material 5_Sclera
KdColor 1 1 1 1
KaColor 1 1 1 0
KsColor 0.14902 0.14902 0.14902 1
TextureColor 1 1 1 1
NsExponent 50
tMin 0
tMax 0
tExpo 0
bumpStrength 1
ksIgnoreTexture 0
reflectThruLights 1
reflectThruKd 0
textureMap ":Runtime:Textures:TrekkieGrrrl:Severus:Eyes_Blue.jpg"
0 0
bumpMap "NO_MAP"
reflectionMap "NO_MAP"
transparencyMap "NO_MAP"
ReflectionColor 1 1 1 1
reflectionStrength 1
shaderTree
node "poser" "PoserSurface"
name "PoserSurface"
pos 10 10
showPreview 1
nodeInput "Diffuse_Color"
name "Diffuse_Color"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node "Image_Map"
file "NO_MAP"
nodeInput "Diffuse_Value"
name "Diffuse_Value"
value 1 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Highlight_Color"
name "Specular_Color"
value 0.14902 0.14902 0.14902
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node "Image_Map"
file "NO_MAP"
nodeInput "Highlight_Value"
name "Specular_Value"
value 1 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Roughness"
name "Highlight_Size"
value 0.02 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Ambient_Color"
name "Ambient_Color"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Ambient_Value"
name "Ambient_Value"
value 0 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Transparency_Max"
name "Transparency"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Transparency_Min"
name "Transparency_Edge"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Transparency_Falloff"
name "Transparency_Falloff"
value 0 0 100
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Translucence_Color"
name "Translucence_Color"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Translucence_Value"
name "Translucence_Value"
value 0 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Reflection_Color"
name "Reflection_Color"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Reflection_Value"
name "Reflection_Value"
value 1 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Refraction_Color"
name "Refraction_Color"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Refraction_Value"
name "Refraction_Value"
value 1 0 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Bump"
name "Bump"
value 1 -10 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Displacement"
name "Displacement"
value 1 -10 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "AlternateDiffuse"
name "Alternate_Diffuse"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "AlternateSpecular"
name "Alternate_Specular"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "ReflectionLiteMult"
name "Reflection_Lite_Mult"
value 1 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "ReflectionKdMult"
name "Reflection_Kd_Mult"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Gradient_Bump"
name "Gradient_Bump"
value 1 -1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "ShadowCatchOnly"
name "Shadow_Catch_Only"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "ToonID"
name "ToonID"
value 36 0 32768
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Normals_Forward"
name "Normals_Forward"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
node "image_map" "Image_Map"
name "Color_Texture"
pos 300 10
nodeInput "Image_Source"
name "Image_Source"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ":Runtime:Textures:TrekkieGrrrl:Severus:Eyes_Blue.jpg"
nodeInput "Auto_Fit"
name "Auto_Fit"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "U_Scale"
name "U_Scale"
value 1 -1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "V_Scale"
name "V_Scale"
value 1 -1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "U_Offset"
name "U_Offset"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "V_Offset"
name "V_Offset"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Texture_Coords"
name "Texture_Coords"
value 1 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Image_Mapped"
name "Image_Mapped"
value 4 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Background"
name "Background"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Global_Coordinates"
name "Global_Coordinates"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Mirror_U"
name "Mirror_U"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Mirror_V"
name "Mirror_V"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Texture_Strength"
name "Texture_Strength"
value 1 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
nodeInput "Filtering"
name "Filtering"
value 3 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file "NO_MAP"
