Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
I'm still very new to poser. Now I've got Victoria working, I'm wanting to apply some of the stuff I've downloaded. A lot of the clothing I have appears in the poses section of the library. Could someone explain how to apply these to the figure please? When I double click on the pose, not a lot happens, so I'm guessing it's a little more complicated than that
Thanks again
Actually, what you see in the poses library is what gets applied to the clothing figure. Thus - if you don't load a clothing figure first, nothing happens.
Just as you load Victoria 4.2 base figure, and then get morphs and textures to apply in the poses library, so too with clothing: The actual clothing figure is usually loaded from the figures library. Then you choose your corresponding clothing textures from the poses library.
______________
I had a similar problem installing Victoria 4.2 into Poser Pro, created a fake Poser.exe file & it seemed to installed successfully. But there is no sign of Victoria when I look for her from within Poser Pro. I can see the files in the RuntimeLibraries folder (in a folder called "!DAZ"), but I've searched every single Figure folder from within Poser Pro & it's not there. Anyone have any ideas about what may be happening & how to fix it?
"Every child is an artist.
The problem is how to remain an artist once we grow up."
Picasso
Ok, never mind, I figured out how to fix this. When I installed Poser Pro, I set up a separate Download content library (as recommended). So I uninstalled the Victoria 4.2 I had installed in the Poser Pro application folder & re-installed it in my Download content folder (after first putting a fake Poser.exe file in it to satisfy the DAZ installer). Poser Pro was then able to find it & all seems to be working fine now.
Picasso
I've been having problems installing Victoria 4.2 into Poser Pro. When i try to install PS_Pe069_Victoria4 into the PoserPro directory, which contains the Executable file, i get a PopUp saying it needs to be put into the directory with the Executable file.
Is there any different way to do it in Poser Pro? I've installed it into Daz3D but much prefer Poser. I'm really inept with installing things like this.
Thanks in advance for your help
