Sun, Dec 1, 5:39 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Help With SD Card
beachzz ( ) posted Fri, 15 May 2009 at 11:35 PM · edited Sun, 01 December 2024 at 12:02 PM
I was on vacation and bought a new SD card for my camera (Fuji S700).  I can't get it to upload to my computer, tried locking and unlocking it.  Anyone got any suggestions?  Thanks.
bclaytonphoto ( ) posted Sat, 16 May 2009 at 12:10 AM
are you using a card reader or straight from the camera?
can you see the images on your camera?
How does the camera show up on your computer? as another drive?
Check the cable..
www.bclaytonphoto.com
bclaytonphoto on Facebook
beachzz ( ) posted Sat, 16 May 2009 at 12:19 AM
a card reader
yes
when i put the card in, it opens a window that says "removable disk E", but the bad card doesn't register at all
the cable is fine, i used it earlier with the original card
Fred255 ( ) posted Sat, 16 May 2009 at 4:58 AM
Attached Link: SD / SDHC Memory Card Reader
is your SD card one of the new SDHC cards?  If so you need special adapters for them to be read.
 ecurb - The Devil
beachzz ( ) posted Sat, 16 May 2009 at 10:49 AM
Hmmm, I'm not sure, I'll have to look at it again.  Thanks.
bclaytonphoto ( ) posted Sat, 16 May 2009 at 4:12 PM
If this is the same type of card you normally use..I'm not sure..
When your window opens...
close that
then go to "my computer"
try going to it from that direction..
Can you please post the exact card reader you have?
Do you have a cable to connect your camera to the computer? maybe you could try that
The PC may need to be restarted in some cases..
beachzz ( ) posted Sat, 16 May 2009 at 10:04 PM
the card reader is a Targus,usb, 2.0.   I don't have a cable for thecamera, but might see about getting one. I'll also try your other suggestion.  Thanks so much.
bclaytonphoto ( ) posted Sun, 17 May 2009 at 10:34 AM
There are a couple of models..
http://www.walmart.com/catalog/product.do?product_id=9722059
http://www.walmart.com/catalog/product.do?product_id=10038332&findingMethod=rr
http://www.walmart.com/catalog/product.do?product_id=9722060&findingMethod=rr
If you have the first one..(a multi card reader) You should see several drives when you have it hooked up.
At least, that's the way mine does on Windows XP
The other ones, I'm thinking it will show up as a single drive.
The fact that you can see the image while the card is in the camera, tells me, the card is mostly likely OK, and there seems to be an issue elsewhere
Try this..
Take a different card (assuming you have one) take a few shots and see if you can view that from the computer
beachzz ( ) posted Sun, 17 May 2009 at 10:39 AM
Thanks so much for all your info, I'll try all of your ideas; one way or another I'll get those pix!!
I do have another card; I bought this one when I was in Hawaii just so I wouldn't run out of memory; the other one works just fine.
