Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 7:24 am)
No it just says DLLs - I've right clicked the exe file and ran in compatibility mode - also made sure I'm running as administrator.. all didn't work. I've googled the problem and basically learned that lots of people had the same problem and at the time there seemed to be no answer. Hoping by now someone would have solved it... Thanks for you reply
My own story, I loaded Poser in the Xp compatibility mode) to my Programs Files X86 section and finally got it to run with cliching. The first couple of time I did it, didn't work right. What I finally did: Completely uninstalled Poser, went through everything manually to get rid of bits and pieces, used McAfee files cleaner and clean mgr then defragged, (had several cups of coffee along the way, threathened to condemn Vista to the very depths of Hadies, loaded it in Compatability mode, opened it in compatability mode and it now works fine. Other folks state that placing it directly in your root directory works too. Loading it to an external drive is a big no-no (tried that too). Jan
I'm running Vista Business and installed P5 to the harddrive on its own outside of the Program Files (either one). Been working fine along my P6 installed "normally".
Granted, I don't use P5 much anymore, but it's behaved normaly when I've opened it.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser
goodies and so much more!
This has prob been asked lots of times but I've just come back to Poser... My Poser 4 works fine with Vista but my Poser 5 brings up an error message saying the program requires certain Dlls to run - reboot or reinstall. I've rebooted and reinstalled to no avail. Any way to get Poser 5 to run with Vista? (Both original purchased programs not cracked copies etc).
Thanks for any help.
DelsArt
