velarde, When eovia first announced themselves, I remember it being mentioned in one of the articles that talked about eovia's plans for Carrara. However I have not seen anything directly from eovia mentioning flash so it may be my faulty memory or the imagination of the reporter. Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
velarde - I don't know about going from Carrara directly to .swf. what I generally do it render the movie as a series of bmps or gifs or jpegs (depends on my mood.) Then I go over to flash and import the first image into a new layer. It then prompts you if you want to import the entire sequence, click yes and it will create a keyframed animation with each image in it's own keyframe. But if you don't have flash then it's kind of useless. You can download a 30 day trial of it at the macromedia site though. Or find a friend that will keyframe the movie for you :) Good luck to you! Jared
And yet another question... Do you know if there is somebody out there developing a plug-in or module that will allow people to render animation in Carrara in the .swf (flash) format? Eovia? maybe in the next release...
