Wed, Dec 11, 2:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 10 5:41 pm)
Subject: Poser 8 light attenuation question
Whichway ( ) posted Wed, 05 August 2009 at 5:43 AM · edited Tue, 03 December 2024 at 4:10 PM
I have a question about the normalization of the new linear and quadratic fall-off lights in P8. If I have three point lights at the same place, all with identical intensities but one constant, one linear and one quadratic, at what distances are the fluxes pair-wise the same?
Whichway
ice-boy ( ) posted Wed, 05 August 2009 at 5:54 AM
why would you have 3 point lights at the same place?
Whichway ( ) posted Wed, 05 August 2009 at 6:16 AM
It's a theoretical question trying to get at how their algorithm actually works. My guess is going to be that they all match at one natural Poser unit from the lights. Another way to think about the question is: If I have a Poser 7 light set and want to use it in Poser 8 with linear/quadratic lights instead, how should their intensities be chaged to keep the light on the primary subject the same? It's going to depend on the distances from the subject to each light.
Whichway
ice-boy ( ) posted Wed, 05 August 2009 at 6:32 AM
''how should their intensities be chaged to keep the light on the primary subject the same?''
i think you will need to do test renders.
bagginsbill ( ) posted Wed, 05 August 2009 at 6:47 AM
I'm pretty sure you're right about 1 PNU. The curve is adjusted so that the selected intensity happens at a distance of 1 PNU, regardless of which falloff setting is chosen.
