Thu, Feb 27, 2:18 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Cloth Room Presets
Crispycraft ( ) posted Fri, 11 September 2009 at 3:27 PM · edited Thu, 27 February 2025 at 2:16 AM
I was just given some cloth room presets (I guess that's what you would call them) and I installed them via the path that I was instructed to do so, but I don't see anything when I am in the clothing room. I opened the Python tab, but there was nothing there.
The path I was given was:
Runtime/Python/poserscripts/scriptsmenu
The trouble I found with that was that I didn't have the "scriptsmenu" folder so I made one. But Still nothing. Am I not searching in the correct place?
TrekkieGrrrl ( ) posted Fri, 11 September 2009 at 4:15 PM
 Which presets exactly? It always helps to be specific.
I have some I got from PhilC once. But I must admit that short of downloading them, I haven't tried them out so I'm not sure what format thery're in or what they do ...
Crispycraft ( ) posted Fri, 11 September 2009 at 4:27 PM
Yeah, I have the PhilC also, but I had just received some from Fugazi1968. They are all .py files. I did figure out that I could open the Python window and load them into script like that, but Fugazi1968 has them in his tool bar.
grichter ( ) posted Fri, 11 September 2009 at 4:30 PM
 Dumb comment. If you load new scripts in the scripts menu, you have to restart poser before they will show up.
You should have had a scripts menu. In Poser if you click on the scripts pull down at the top and to the right, do you see anything?
Gary
Crispycraft ( ) posted Fri, 11 September 2009 at 4:38 PM
There's no "Scripts" there. That's what I'm trying to tell you. LOL! And, yes, I did restart poser after installing them. Is there some kind of addon that I need for the scripts tool bar tab? And, no, there's no scriptsmenu folder in my poser unless it's not in the location noted above.
PhilC ( ) posted Fri, 11 September 2009 at 5:53 PM
Which version of Poser are you using? The "Scripts" menu started with Poser 7.
Crispycraft ( ) posted Fri, 11 September 2009 at 5:59 PM
Well that explains a lot! LMAO! Poser 6 is what I have. HAHAHA!!!
Man, that was a good catch, PhilC. That also relieves a lot of frustration. Man...like 1000mg of Ibuprofen just kicked in. HA!
I found that I can add them individually in the Python Script window so I guess that's what I will continue to do until I finally upgrade.
