Fri, Nov 29, 10:16 AM CST
Subject: Subfolders for .mat files and objects
GreenHawke ( ) posted Sun, 20 September 2009 at 6:35 PM · edited Fri, 29 November 2024 at 10:09 AM
Hi all!
I followed a how-to on making sub-folders/directories for my own materials and objects online and had no success and have been unable to relocate it.
Does anyone know of a "quick and easy" way of accomplishing this?
Thanks!
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...'
Isaac Asimov (1920 - 1992)
TheBryster ( ) posted Mon, 21 September 2009 at 8:13 AM · edited Mon, 21 September 2009 at 8:21 AM
Forum Moderator
I'm assuming you use B6.1
In your Bryce Presets Objects folder you should see two folders - Installed and User.
Copy the USER folder and paste it somewhere outside the Bryce folder.
Rename it to something like 'User 2' (or something that indicates what it will contain).
Delete the USER.OBP it contains.
Drop the objects you need into it. (My object 1.obp - My Object 2.obp etc)
Paste it back into your Bryce Presets Objects folder.
Open up Bryce.
Open the CREATE tab.
Go to the bottom of the drop-down - where it says 'INSTALLED' and click the little down arrow.
You should see 3 items.
Installed
User
User 2
User 2 should contain all the OBPs you just added.
(The folder that you copied and pasted outside your Bryce folder can now be used again for making another sub-folder so that you can repeat the above process.)
This works for Materials and Skies too.
Hope this helps.
GreenHawke ( ) posted Mon, 21 September 2009 at 8:48 AM
Quote - I'm assuming you use B6.1
Actually, I am using Bryce 5.5 - the "free" version.  I'm poor..  :-)
Will this still work?
And thanks for the reply!
GreenHawke ( ) posted Mon, 21 September 2009 at 9:13 AM
I'm guessing that v5.5 is different as there is no "user" directory.
GreenHawke ( ) posted Mon, 21 September 2009 at 9:19 AM
Ooops!!!
Got it!  Worked fine.  Thanks very much!
