Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
I run P7 on Vista on my desktop with no issues. I do recall needing to do a few things to get it to run properly (like running it compatibilty mode. I tried to run it on a different system with Vista and it worked fine, except for importing audio. It wouldn't recognize any audio I tried to use. Even audio I know worked.
Now Playing
My Insomnia Presents
Blue Defender
I did things like turning off Aero, indexing and other things just to free the computer up for more important tasks, but not necessary (although Aero is a memory hog). As for running Poser 7, it does run much, much better for me if when I render, I render as a separate process. Poser 6 will bog down for me if I try to cancel a render in progress at which point I normally need to just close the program. Other than that, it runs fine.
My laptop will have 3gb of RAM and runs with 2.5 ghz speed.
Better than my desktop for that but I'll be learning hands on with vista.
Which I'm not worried about, I learned each Windows platform by hands on with no help, but just wondered how well Poser works with it.
Thanks for feedback.
If your laptop has an integrated video card, it will slow down somewhat.
Now Playing
Blue Defender
I've run all Poser versions (except 7Pro since I don't have that) on Vista with no problems. Vista is fine for running Poser.
You MAY like to turn off the UAC (User Access Control) - Vista is overly paranoid and I know it can cause problems at least with Poser 8.
Also, do not install Poser into C:Program Files - Vista is silly and is again overly paranoid with that area - so some programs may not be able to run from that location.
Most places, if you buy a new computer with Vista at the moment, it will include a free upgrade to Windows 7. But I've never had problems with my Vista. Then again I LIKED WindowsME and Poser 5, too....
I've been running Poser 6, 7, and Pro on Vista, then all those plus Poser 8 on Vista64 with no trouble. I'm testing Windows 7 x64 now with Poser Pro and Poser 8, again no problems at all.
For any flavour of Vista I'd recommend:
don't install Poser to the default directory, or even the default drive. If you have to, partition your drive so you have enough room on C: for the OS and other stuff and enough on the other partition for Programs and data.
turn off UAC (Google it!)
turn off all the flashy GUI 'enhancements'
PoserPro 11 - Units: Metres
Adobe CC 2017
No problems with P7 or P7 Pro on Vista, and Poser Pro at least works great on Windows 7 (x64) too.
I haven't tried P7 on Windows 7, and haven't bought P8 yet. In spite of what you may have read elsewhere here recently. ;-)
Blue Echo, if you can get that laptop with Windows 7, or at least with a discount to upgrade to Windows 7, I'd recommend that over Vista. I used to be a die-hard Vista fanboy, but not since I installed Windows 7, which is soooooo much better in so many ways.
I too have no problems with Vista and Poser 7. It came with a new laptop, and no choice without spending lots more money that I dont have :) UAC did get turned off somehow, still not sure how that happened but since I am the only user it doesnt seem to make a difference except get rid of some annoying messages.
My new comp will be here today, now I need to find out how much a multiple use license costs.
I want P7 on both computers but I can't find where to get this information.
I searched the site but no luck so far...sigh.
Maybe it's just me but I don't get those "turn UAC off" comments you get every time with vista.
Every little security feature is just fine with me. But I'm sort of paranoid anyways, comes with my job description sorta.
I'm running P7 and P7pro on vista with uac on (obviously) without problems on desktop.
Haven't tried Pro but my P7 gave unexpected crashes on my Vista laptop. Most likely related to the nvidia 8600M-GT graphics chip. Never liked the small(er) resolution display much so I didn't put much effort in solving the problems.
Lucifer-The-Dark, thank you for the reply about Poser.
I also found that since my Poser program is on an external drive, it will still work when I connect it to the laptop, :)
And I tried a render with it on the laptop...works great and fast. BG
I've been running Poser 7 on Vista for two years and have had no problems which relate to the OS. The only trouble P7 has given me has been some complications with a few Python scripts which were developed for earlier versions.
Are there any problems using Poser 6 and 7 on a Windows vista platform?
I am getting a Compaq laptop Duel-core cpu with Windows Vista and would like to know what to expect in performance with Vista.
